newbie here..
can RA control:
1. jebao wp25-
2. marine magic dosing pump
3. led light it2040
4. reef octopus ATO
5. jebao dc pump
thanks in advance
few question
Re: few question
1. jebao wp25- yes
2. marine magic dosing pump - no
3. led light it2040 - no
4. reef octopus ATO - no
5. jebao dc pump - yes
The no's could be maybes...a lot of investigation being done to hack the evergrows...at your own risk
The ato could be enhanced by an RA float switch or water level sensor as a backup
If its the slave dosing pump without the controller than yes. If its the triple unit no, if its the master or triple you could disable if ph goes whacky for some reason but you cant control the dosing or anything. You need a standalone pump like the slave pump or brs or ra dosing pump.
