If I want to change the labels for the temperature probes in my RAGen built pde to something similar to the preloaded file, do I need to change one of the library codes or can I add change it within my pde file?
I have 3 probes and I'd like a better reminder which one is which (Tank, Sump, or Canopy)
Jon
Labelling Temp Probes
- jsclownfish
Re: Labelling Temp Probes
change the labels displayed where? the labels on the controller display cannot be changed. the labels on the other apps (ipad/iphone, android, client suite, web banner) can be changed though.jsclownfish wrote:If I want to change the labels for the temperature probes in my RAGen built pde to something similar to the preloaded file, do I need to change one of the library codes or can I add change it within my pde file?
Jon
You can change the labels on the controller screen if you design your own custom main screen.
Take a look at this code from Marcelo with some screenshots.
http://forum.reefangel.com/viewtopic.php?f=11&t=255
If this is something you would like to pursue, there is a guide that Curt put together.
http://forum.reefangel.com/viewtopic.php?f=14&t=109
If you get stuck anywhere, let me know.
Oh yeah. I forgot that I created the custom main screen stuff that allows you to fully configure the display.
Guess I had better turn my brain ON before I start commenting. Thanks Roberto for catching that one.
