Chinese made LED diy
Re: Chinese made LED diy
Okay I got a email back from the supplier:
" oh no, the 36v power supply is completely seperate, like a labtop battery. They plug into the dimmers that we have that are 5v-36v dimmers and then those plug into the light. The power supplies we have are not dimmable power supplies but you could get some that are. Basically it just needs to be 36V going into this fixture... X 2 Because we have one power cord going in to the whites and one for the blues. "
So based off that the drivers are seperate. Therefore I should be able to get a driver from rapidleds?
Ill get some picture here now
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Pic
- uploadfromtaptalk1382564801213.jpg (151.81 KiB) Viewed 6790 times
Yup. So they may be dimmable if I get the right drivers then?
I've never opened up one of those fixtures before, so I can't guarantee...
Search for ecoxotic DIY driver and do your research, but it seems doable.
I talked to a representative at rapidleds and they seem to have a driver thats compatible and will possible work. Ill let everyone know how one goes.So could I splice the dimmer signal of two different drivers which control the same colors into the same port ?
Yeap
You can connect multiple drivers in the same port, but they will dim all together.
Awesome . Ive ordered the drivers (2 ) , just for the whites. Is the anyway you can take a look at the thread I posted about the code guru help?
Dang just realized I ordered pwm signal drivers and I have a analog controller. .
I'm going to work on mine soon. I think it can be dimmed with a simple opto isolator with the arduino 5v dimming on one side and the 12v dim supply voltage and dimming pin on the other side.
Yes, please let us know how it goes and how you connected everything together as this is most likely going to help someone else in the future.
Okay everyone the LED drivers I bought from rapidleds dim my LEDS! I hooked up everything this morning and It seems to be working great so far. All i had to do is cut the old 36V transformers from the line and i replaced it with the meanwell Drivers. I only bought 2 drivers to test before i committed to buying 4 of the drivers, I only hooked up the whites to the drivers. here's a link to the lights and drivers i used.
Ill post a picture and a video of the fixtures once I get the other drivers.
http://www.rapidled.com/mean-well-eln-6 ... le-driver/
http://www.ebay.com/itm/Aquarium-LED-Li ... 0915148718
Great to hear.
What size tank do you have?
I think you said you have 2 light modules.
What are the actual dimensions.
According to some spec I found on Alibaba.com 300x260x60mm which equals 11.811 x 10.2362 x 2.3622.
Does that sound about right?
I'm trying to see how many I would need for a 55 gallon tank. 48" long 12" Wide 21" Deep.
I'm thinking 2.
2 of these and 4 drivers is just over $400 including shipping on the drivers.
Not a bad price.
I'm thinking 2.
Not a bad price.
That is exactly what i have a 55 gallon and I have 2 fixtures. they seem to grow everything I have: and are pretty powerful atleast in my noobie opinion. I have to acclimate my corals at a certain depth for awhile before i can move them up in the tank.
Im adding a actinic strip from rapid leds as soon as I replenish some funds. I want a more 2:1 ratio of B:W
My tank has been running with these lights for 8 weeks approx and my open brain has atleast doubled in size since then, however I do spot feed once a week.
Im by no means saying these lights will work for everyone, I took a noob chance and ordered the cheaper fixtures from ebay and so far they have worked fine, Im not sure what kinda longevity I will get out of these. They have no fans but the transformer/driver is outside the fixture so it doesnt contribute to the overall heat inside the canopy. I plan to add some fans to my canopy soon to help keep the fixture cool. Im sure if you have a open top the LEDS shouldnt need a fan or two.
Sacohen wrote:What are the actual dimensions.
I'm thinking 2.
Not a bad price.
Yeah. Right now I have no canopy and just 1/4" mesh screen over the tank.
I have to build up some funds. I just spent a bunch on a Jebao DC 6000 pump and a RO/DI unit.
I've looked at lots of options and short of a DIY setup this is the least expensive I can come up with that meets my needs.
As far as longevity, I took a chance on the Jebao WP-40 and 25 so I'm willing to gamble a bit.
If you have a standard 55 there is a bar in the middle of it, so I guess you have 1 fixture on each side.
Yes exactly I have one on each side. the Jebao wp-40 Is definitely my next upgrade.Sacohen wrote:Yeah. Right now I have no canopy and just 1/4" mesh screen over the tank.
Thanks. There have been some reported problems with the Jebao pumps, but they are few.
I've had not problems with my 40 and 25. I hope my DC-6000 is just as good.
There is a group buy on Reef2Reef for the Jebao.
The last day to order and pay is Nov 1.
http://www.reef2reef.com/forums/richmon ... p-buy.html
Dang those jebao are super cool. Thanks for the heads up . Im not a member of the forum so ill have to register and possible jump in on the group buy.
What size are you using in your 55 gallon jebao?Sacohen wrote:Thanks. There have been some reported problems with the Jebao pumps, but they are few.
I'm using a WP-40 and 25 controlled by the Reef Angel in Anti-Sync.
There is custom code in my INO that lnevo created for paultruner911 and helped me incorporate into my code to randomly change the mode of the DC pump every day or on reboot of the controller.
Ive got 2 other circulation pumps a small 500 and a 700 gph. I would have way too much current. I think I may get the bigger one and try it out. What do you mean DC pump? Is that the return pump?
The DCPump class is code that was set up to handle any of the pumps like the Jebao that run off DC power instead of 110V AC power.
It applies to the return pumps or the WP pumps.
I just saw that you got in on the Group Buy on Reef2Reef and got a WP-40 and a DC6000.
Congratulations.
Congratulations.
Sure did. I swear , this is a addiction . Now all ive got to get is the two other drivers and ill be set. Sounds like we will be running a similar setup maybe, maybe we can help each other with the codes
Sure. Not a problem. I keep my code updated in the PDE/INO section & there is a link in ny sig.
Dctrojan; I just wanted to see how you are liking the light still?
The only thing I noticed about them when I looked at them on Ebay is there is no reds, pretty much just blue, whit and a little green.
So I did more testing Sunday with the other header on the power supply with 12v, gnd, and dim but had no success getting it to do anything via pwm. I traced out some things on the driver board and there are some un-populated components along the path so I believe this is why it won't work. I'm going to just use an i2c dual channel digital potentiometer to do the dimming.
Can you explain this option? Do you have a part already that does this or is this something that needs to be built?
