Link to Official App:
https://itunes.apple.com/us/app/reef-an ... ?ls=1&mt=8
This has been LONG overdue.
First off, I must say my apologies for the delay. Most of you will chime in, "it's ok" or "no worries" but I still feel I need to say it. I had to learn Objective-C and iOS programming to accomplish this task. It was different and things are still a work in progress.
Now, with that being said, on to the "good stuff". This new app is built for iOS 7 and later. It will not work on iOS 6 devices, so for those devices you should use the existing ReefAngel app created by John.
The app is currently designed to work for iPhone devices in portrait mode but will run on iPad devices in expanded compatibility mode.
Current Features:
- Displays current status from controller (does not work with the Portal).
- App configured from the Settings app in iOS. The hostname or IP of your controller is entered here and is needed for the app to work.
- Displays the main relay
- Toggle the relay status for each port
- Added Feeding Mode, Water Change Mode, and Exit Mode buttons at the bottom of the screen
- Fixed up the display issue/artifacts with the app icon
- Changed the black/carbon background to white
Current iTunes Store Status: v1.1.0 Released
As of: 2/21/2013
For those of you who are interested, I have posted the source code for this project on my github account. The project is called iosStatus.
Download here:
Or use the link in my signature.....Enjoy!
