ATO alarm remote reset
riggeek
Post by riggeek »
I know I have read on the forum some where about reset a ATO alarm while away from home.
I have not been able to find this info again thou.
What is the best way to set up to be able to do this remotely?
thanks
riggeek
riggeek
Re: ATO alarm remote reset
http://reefangel:2000/mt
Replace reefangel with your dyn dns name or remote ip
riggeek wrote:I know I have read on the forum some where about reset a ATO alarm while away from home.
thanks
riggeek
that depends on what you use while away from home. the android app makes it really easy as there is a button on the Commands page that clears it for you. otherwise, I don't recall if this capability is in the portal. I would think that it is but I don't use the portal so I can't confirm. the last choice is to use the direct command from a web browser to clear it.
http://YOURIP:2000/mt
that's the direct command to clear it.
Sent from my Nexus 7
riggeek
Post by riggeek »
thanks for the info everyone.
I will work on this when I get home in about 1.5 weeks
riggeek
