Sunrise / sunset code based on location
Re: Sunrise / sunset code based on location
If you look inside the ReefAngel.cpp line 1054, you will see that they are the exact same thing :)
void ReefAngelClass::DayLights(byte Relay)
	StandardLights(Relay);
Latest version I'm using
SunLocation.zip
(4.17 KiB) Downloaded 458 times
DesignInstinct
Re: Dawn/dusk simulator
Post by DesignInstinct »
Hi, I'm looking for somebody to assist with a standalone Arduino project using this code to control LED lights.
Want to simulate accurate sunrise/set times...and *proper* twilight length of 60-90 minutes.
Need to ramp the LED lights smoothly over this time period. Just like what happens when looking out a window at the sun. Want to match real life fairly closely.
I'm also going to purchase a Reef Angel Plus anyway to do aquaponics/greenhouse control.
I'm NOT a programmer...but very computer literate.
Would NOT like to become a programmer ;)
Far too busy with other projects in other fields.
Will gladly pay to have this "done" for me.
Would like to do a lot of it over Team Viewer in realtime (voice/video).
I can work faster this way. Yes, they have Team Viewer for Linux. I'm on Win 8.1.
"Several inexpensive “light alarm clocks” have been marketed, cloning the DDS concept, but with rapid dawn ramps (far faster than natural dawns) and restricted fields of illumination. These mass-market products have not yet received adequate clinical evaluation. "
Yeah...that's an understatement.
Can't post links here so PM me for similar devices and why they fail at doing this.
This will benefit reef tanks, greenhouse applications, and humans living in dark houses up North.
I want to simulate sunrise/sunset and evening lighting no matter what the cloud cover outside. May be moving from New Mexico back to the frozen North and will need this badly. Most people need this and don't even know it.
Any improvements to the Reef Angel code and the standalone Arduino version code would be kept open source. This stuff is too important to be proprietary.
Google gizmag NASA led lights
Gonna let NASA and Boeing steal our thunder?
Any takers? Reply here, PM me whatever!
89delta
Post by 89delta »
lnevo....
I've just finished compiling my sketch for my RA+ I recently got and it works great. Am using the Clouds and weather patterns on the standard pwm channels from http://forum.reefangel.com/viewtopic.ph ... 8&start=50. ButI was wondering how to incorporate the location based sunrise/sunset code into it as i've only seen it being used for the standard lights on relays. Thanks for any help.
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, COLOR_WHITE, 6, 4, " Martin's BC29");
ReefAngel.LCD.DrawDate(6, 118);
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 17, 132, 17);
x = 12;
y += MENU_START_ROW+1;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, " Display      PH");
char text[7];
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text);
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(16*4),y+16);
ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y, text);
x += (16*4) + 8;
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,8,y+25,"Hood:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor,
9, y+35, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+25,"Room:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], T3TempColor,
x+9, y+35, 10);
//ReefAngel.LCD.DrawText(0,255,20,80,MoonPhaseLabel());
    //ReefAngel.Use2014Screen();  // Let's use 2014 Screen
    ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardHeater( Port2 );
    ReefAngel.DosingPumpRepeat1( Port4 );
    ReefAngel.DosingPumpRepeat2( Port5 );
    ReefAngel.StandardATO( Port6 );
    //ReefAngel.PWM.SetDaylight( MoonPhase() );
    //ReefAngel.PWM.SetActinic( MoonPhase() );
    ReefAngel.Portal( "89delta" );
  // Calculate your regular sunrise/sunset PWM value
  ActinicPWMValue=PWMSlope(10,00,22,15,0,50,40,ActinicPWMValue);
  DaylightPWMValue=PWMSlope(10,00,22,15,0,50,40,DaylightPWMValue);
  CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 50
#define Min_Cloud_Duration 5
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      if ((cloudstart/60)>=10) x=11; else x=17;
      if ((cloudstart%60)>=10) x=29; else x=35;
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
      if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
You would use it in the section that says Calculate your regular sunrise/sunset PWM value. The sunlocation class which i dont see declared will have methods to get the rise hour/minute and set hour/minute. You'll plug those into the pwmslope function arguments.
89delta
Post by 89delta »
Thanks for the fast reply lnevo...I know i've still gotta add the rest of the code to my sketch, but something like this:
#include <SunLocation.h>
SunLocation sl;
byte x = 6;
byte y = 2;
byte t;
x = 12;
char text[7];
x = 10;
x += (16*4) + 8;
9, y+35, 10);
x+9, y+35, 10);
  sl.Init(-18.285833, 147.699722); // In decimal numbers (i.e. -18.285833, 147.699722)
    // handle updating sunrise and sunset values
    sl.CheckAndUpdate();
    sl.SetOffset(0,0,0,0); // rise_hour, rise_seconds, set_hour, set_seconds
  ActinicPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),0,50,40,ActinicPWMValue);
  DaylightPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),0,50,40,DaylightPWMValue);
  CheckCloud();
void CheckCloud()
#define Min_Cloud_Duration 6
#else
#endif
      if (cloudchance)
  if (cloudchance)
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
I see you figured it out! Yes exactly :) let us know if that worked for you?
89delta
Post by 89delta »
Nice....thanks for looking lnevo. My other question is in regards to the moon phases. Can I use sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute() in switching over to the moonphase() for my blue leds after the day has finished.
Yes, but you might want to also look at my moon rise/set class that you can use too which calculates the rise/set times for the the Moon :) However, you can use the sl.GetXXX() for whatever scheduling you want. You could also look at the option sl.UseMemory=true which will set the StandardLight schedule into memory so you could have other devices that aren't dimming let's say based off the sunrise/sunset schedule.
89delta
Post by 89delta »
How would I incorporate your moon class into it lnevo.....thanks for your help.
89delta
Post by 89delta »
Sweet....thank lnevo. Will try it out tonight when i get home.
Sent from my SAMSUNG-SGH-I717 using Tapatalk
89delta
Post by 89delta »
So everything is working correctly with my sketch, Sunrise/sunset, Weather and moon phases. Although i've noticed that the sunrise/sunset times don't really change but by +/- 2 minutes. Is that normal for the most part? My Long/Lat is set to the GBR between Paul Reef and Storm Reef off of Queensland,AU.
sl.Init(-21.285833, 150.999722); // In decimal numbers (i.e. -18.285833, 147.699722)
sl.SetOffset(11,0,11,0); // rise_hour, rise_seconds, set_hour, set_seconds
Yep, try tracking it over the course of a month or two. Area's closer to the equator are going to have the smallest amount of shift daily as the fluctuation is only going to be +/- 2 hours or so over the course of the seasons.
89delta
Post by 89delta »
Ok, thanks for the clarification lnevo. Love everything you guys have done with coding and everything else.
