Jebao wp-25
Jebao wp-25
Wonder how and where I connect the Jebao cable to controll the pump. Is it inte dimming ports on the relay box?
Re: Jebao wp-25
Yes. Either the Actinic or the Daylight dimming port on the relay box. Or on any open port on either of the dimming expansions if you have one of those as well.
~Charlie
~Charlie
Re: Jebao wp-25
ok do i neeed to change any settings?
Re: Jebao wp-25
You're using the RA Jebao cable from the Web Store, yes? As long as you are using that cable you can plug it right into one of the open ports on the relay box. After you do that you can write/change your code as necessary to run the pump(s).
Re: Jebao wp-25
yes I am using that cable. Yes I think i've found the settings in Reef angel wizzard
Re: Jebao wp-25
Should the actinic or daylight port be on sync or antisync?
Re: Jebao wp-25
Those only come into play if you have 2 Jebao pumps and you want them to run opposite of each other.
If you only have 1 pump then it should be Sync.
Re: Jebao wp-25
Now it works, but I can not change the program. If I choose short pulse so it is left in the reef crest. What is wrong? I use the controller in the web browser. Do I need to upload programs reef crest, short pulse etc?
Re: Jebao wp-25
Can you upload your code so I can look to see if it is configured to use the DCpump class correctly?
Re: Jebao wp-25
I think I found the error. I had the dimming settings at override. Pushed to cancel the override and it worked
