I can remove the DisplayImages but it still only gets me down to 32408 and I happen to like the images
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
//#include <ReefAngel_Salinity.h>
#include <ReefAngel_AI.h>
byte WhiteValue=0;
byte BlueValue=0;
byte RoyalBlueValue=0;
#define Port8 8
#define Heater 7
#define Port6 6
#define Port5 5
#define FugePH 4
#define PH 3
#define SOL 2
#define FugeLT 1
#define T1LOW 720
#define T1HIGH 850
#define T2LOW 500
#define T2HIGH 850
#define T3LOW 650
#define T3HIGH 1000
// Labels for the web banner
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "wolfador";
prog_char probe1_label[] PROGMEM = "Water";
prog_char probe3_label[] PROGMEM = "Ai%20Nano";
prog_char relay1_label[] PROGMEM = "Fuge%20Light";
prog_char relay2_label[] PROGMEM = "Ai%20Sol%20Nano";
prog_char relay3_label[] PROGMEM = "PowerHead";
prog_char relay4_label[] PROGMEM = "Fuge%20Pump";
prog_char relay5_label[] PROGMEM = "NA";
prog_char relay6_label[] PROGMEM = "NA";
prog_char relay7_label[] PROGMEM = "Heater";
prog_char relay8_label[] PROGMEM = "NA";
void WifiSendAlert(byte id, boolean IsAlert)
static byte alert_status;
if (IsAlert)
if ((alert_status & 1<<(id-1))==0)
alert_status|=1<<(id-1);
Serial.print("GET /status/alert.asp?e=4122988294@txt.att.net&id=");
Serial.println(alert_status,DEC);
Serial.println("\n\n");
if (id==0)
alert_status=0;
delay(900);
alert_status&=~(1<<(id-1));
ReefAngel.LCD.DrawDate(6, 115);
#if defined AI_LED && ! defined RemoveAllLights
ReefAngel.LCD.DrawMonitor(15, 68, ReefAngel.Params);
ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, 70, 78 ,"W:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(0), DPColor, 84, 78, 1);
ReefAngel.LCD.DrawText(APColor , DefaultBGColor, 70, 90 ,"B:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(1), APColor, 84, 90, 1);
ReefAngel.LCD.DrawText(APColor , DefaultBGColor, 94, 90 ,"RB:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(2), APColor, 115, 90, 1);
ReefAngel.LCD.DrawMonitor(15, 65, ReefAngel.Params);
ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 20, 2, "Wolfador's 10G");
ReefAngel.LCD.DrawGraph(5,10);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
WhiteValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,WhiteValue,0,180);
else lightningstatus=0;
if (lightningstatus)
WhiteValue=50;
BlueValue=50;
RoyalBlueValue=50;
WhiteValue=0;
BlueValue=0;
RoyalBlueValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if ((cloudstart/60)>=10) x=11; else x=17;
if ((cloudstart%60)>=10) x=29; else x=35;
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
ReefAngel.Init();
ReefAngel.Timer[4].SetInterval(180);
ReefAngel.Timer[4].Start();
ReefAngel.FeedingModePorts = B00001100;
ReefAngel.WaterChangePorts = B01001100;
//ReefAngel.OverheatShutoffPorts = B10110000;
// ReefAngel.LightsOnPorts = B00000010;
//WifiAuthentication("wolfador:gixxer");
ReefAngel.Relay.On(FugePH);
ReefAngel.Relay.On(PH);
ReefAngel.Relay.On(SOL);
ReefAngel.AI.SetPort(highATOPin);
// Specific functions
ReefAngel.StandardLights(FugeLT,23,0,10,0);
ReefAngel.StandardHeater(Heater);
// Web Banner stuff
ReefAngel.WebBanner();
//This will send an alert if T1 is below 77 and reset if above 78
if (ReefAngel.Params.Temp1<770 && ReefAngel.Params.Temp1>0) WifiSendAlert(3,true);
if (ReefAngel.Params.Temp1>780 && ReefAngel.Params.Temp1<1850) WifiSendAlert(3,false);
//This will send an alert if T1 is above 83 and reset if below 80
if (ReefAngel.Params.Temp1>820 && ReefAngel.Params.Temp1>1850) WifiSendAlert(4,true);
if (ReefAngel.Params.Temp1<800 && ReefAngel.Params.Temp1>0) WifiSendAlert(4,false);
if (hour()>=22 || hour()<9)
ReefAngel.AI.SetChannel(White,0);
ReefAngel.AI.SetChannel(Blue,MoonPhase()*0.06);
ReefAngel.AI.SetChannel(RoyalBlue,MoonPhase()*0.06);
WhiteValue=PWMSlope(9,0,21,0,3,30,200,3);
BlueValue=PWMSlope(9,0,21,0,8,35,240,8);
RoyalBlueValue=PWMSlope(9,0,21,0,8,35,240,8);
CheckCloud();
ReefAngel.AI.SetChannel(White,WhiteValue);
ReefAngel.AI.SetChannel(Blue,BlueValue);
ReefAngel.AI.SetChannel(RoyalBlue,RoyalBlueValue);
//ReefAngel.AI.SetChannel(White,PWMSlope(9,0,21,0,3,30,200,3));
//ReefAngel.AI.SetChannel(Blue,PWMSlope(9,0,21,0,8,35,240,8));
//ReefAngel.AI.SetChannel(RoyalBlue,PWMSlope(9,0,21,0,8,35,240,8));
