Display screen black not responding to joystick
Jbowen590
The display screen started out looking glitchy but I was still about to go through all the menues. Then it cleared the picture but wouldn't change from it's home screen. Now it's completely black and will not respond to any joystick function. Tried resetting and reloading code no change. Please help.
Jbowen590
Re: Display screen black not responding to joystick
Private message you?
Jbowen590
Says I'm not allowed to use private messaging. Do I need to have a certain amount of post to use this feature?
Jbowen590
I figured it would be 5 thanks for the info. Let's see if it works.
c_wick
I'm having the same issue, my screen went blank last night and now it won't turn back on. I've reset the controller, the green power light comes on but no LCD screen
Is the controller still turn on/off relays?
c_wick
No, it's no longer running its program
c_wick
I tried but nothing happen. The arduino software looked to be uploading, it said done uploading but the controller didn't flash, it just stays constant green light on the power
Did you look for any sign of water damage?
c_wick
I don't see any water damage but there was a rattling sound inside so I opened it up and one of the metal brackets that the power cable screws in to to keep it in place was jostling about. Do you think that could have shorted sometime on the board?
c_wick
Roberto, i'm wondering if I should purchase a new head unit board or if I should get a new LCD display? Would the LCD display being out affect my lights not turning on, or would that be controlled by the board?
If the unit is not controlling anything and it is not accepting code upload, it is most likely the head unit board.
If it was just the screen, the controller would still be working.
c_wick
Ok thanks Roberto I'm going to order a new board then. Always appreciate the help.
c_wick
One last question, if I upgrade to the head unit plus is there any change as far as wires and cables to what I have now or is it just more memory? I have the gen 1 LCD display so would that still be compatible?
Yes, screen is compatible.
It's a swap replacement with nothing to be changed, except the head unit board.
Jbowen590
Yeah, your board is setup to use the gen3 screen.
Use this code right above ReefAngel.Init();
InternalMemory.LCDID_write(255);
Jbowen590
this is what my code looks like and screen hasn't changed.
I'm sorry man....
I made a mistake....
Gen 3 screens need this:
InternalMemory.LCDID_write(0);
Jbowen590
Thanks that did the trick. Working great now.
