Help with LongPulseMode
Smotz
Post by Smotz »
Can someone lend a hand? Why isn't this working? It's staying @ 36% & 41%
    if (wpMode==1) wpWavStr=30;
    if (wpMode==2) wpWavStr=33;
    if (wpMode==3) wpWavStr=36;
//Set the Wave OffSet
    wpWavOff=5;
    ReefAngel.PWM.SetDaylight( LongPulseMode(wpWavStr,wpWavStr+wpWavOff,6,true) );
    ReefAngel.PWM.SetActinic( LongPulseMode(wpWavStr,wpWavStr+wpWavOff,6,false) );
Re: Help with LongPulseMode
Smotz
Post by Smotz »
Sorry Roberto, I am just not picking it up - can you give me a bit more guidance?
Here is the link on that post that explains better the function:
http://forum.reefangel.com/viewtopic.php?f=7&t=2844
byte LongPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
PulseMinSpeed - % for minimal speed
PulseMaxSpeed - % for maximum speed
PulseDuration - Duration (seconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
PulseSync - true if you want to sync pumps to same cycle. one false and one true if you want to anti-sync pumps.
Smotz
Post by Smotz »
rimai wrote:Here is the link on that post that explains better the function:
Yea, no help there. Giving up. Going to a different mode.
Thanks anyway.
In your code, you are assinging wpWavStr=36 and wpWavOff=5.
Then you are calling the function like this:
Just replace the variables with the values you are assigning to them and you get this:
LongPulseMode(36,36+5,6,true)
Did you understand now?
Smotz
Post by Smotz »
rimai wrote:In your code, you are assinging wpWavStr=36 and wpWavOff=5.
I get that. so this "LongPulseMode(36,36+5,6,true)" is a valid statement and should translate to long pulse with 36 min, 41 max for 6 seconds each - no?
So why is the wave pattern static and not changing speeds?
It should go 36 to 41 and then 36 again. When one pump is at 36 the other should be at 41 and vice versa. I believe..
Correct. 36 min, 41 max for 6 seconds each pulse.
It goes to 36% stays at 36% for 6 seconds and then goes to 41% and stays at 41% for 6 seconds and repeats the cycle.
Smotz
Post by Smotz »
Gotcha. My point is - it wasn't changing. It was staying at the one speed.
using Sinemode now which is working fine.
Strange...
