Time changing randomly
suburban
I'm very new to this controller, ran into the issue that I set my date and time then I go through the wizard upload my new code, as the day goes on my clock loses time. I cannot set it from the controller since that menu option is gone. I checked my wifi hub it has the correct time so I cannot figure why it's changing. Any help would be greatly appreciated. Thanks.
suburban
Re: Time changing randomly
It is approx six hours ahead. I never see it change so I'm not sure what causes it. A friend thought it may be getting time from my wifi so I checked that it is set correctly. I used the wizard to configure it all seems ok but I loose the menu option to reset the. Time. So I then reset it back to the original settings, change the time then go and upload the code from the wizard again and the time is still correct. About an hour later it was 30 min behind, today it's ahead though.
suburban
Now it went from being ahead to an hour behind our time. I rebooted a couple times no change it stays an hour behind.
I think you will need to send it back for repair.
PM me for RMA.
PM me for RMA.
