Hi Guys,
I am about to purchase the following Aquastyle Online Fixture:
AF-4060 High Power 10W LED 60W dimmable Fixture
It has the following specifications:
6 LEDs
2 x Bridgelux white 10000K
2 x Bridgelux Royal blue
1 x Epiled Actinic violet 420nm
1 x Epiled RGB Mix-white
Each LED is 10W high power
Blue and white light dimmable
(one channel is 2 royal blue and 1 violet, another channel is 2 white and 1 RGB white)
Black anodized surface heatsink with Acrylic splah guard
High efficient Meanwell LPF-40D-42 dimmable drivers
100 degree reflector gives perfect coverage
Royal blue, red, green and violet spectrum benefit reef growth
12cm fan good cooling system
Fixture dimension: 16.5cm(W) x 9cm(H) x 41cm(L) (6.5"x3.5"x16")
Input voltage 100-240V
EU/UK/AU/US plug supplied as required
Can somebody please tell me if this is compatible with my RA+ (PWM) ?
Thanks in advance
Leslie
Aquastyle led light Fixture AF-4060 High Power 10W LED 60W
lmolenmaker
Re: Aquastyle led light Fixture AF-4060 High Power 10W LED
It looks like these meanwell drivers accept PWM or analog. So, you should be fine.
http://www.meanwell.com/search/LPF-40D/LPF-40D-spec.pdf
lmolenmaker
Thanks Roberto.
I went ahead with the purchase of this fixture.
From my understanding this fixture has two channels, but the drivers don't have the pwm connectors, so i need to purchase them myself or...
Now I don't use the supplied Float Switches. Can I cut off the wires and use those connectors to attach them to the drivers, they seem to fit the pwm port on the relay box?
Also I have a Jebao WP25 running on RA (with the special cable purchased on your store) on the actinic channel, so with the lights I am one channel short. Is it possible to move the WP25 cable to one of the ATO ports on the RA? ( as I don't use those ports for now).
Thanks in advance,
Leslie
Thanks in advance,
Leslie
Yes, you can use the float switch connectors. They are the same.
Or buy them in the webstore (Dimming port lead wire).
Yes, you can run the Jebao out of one of the ATO ports, but the cable must be modified.
You can modify it yourself, buy another one and I'll modify it for you or send me yours and I'll do it for you.
lmolenmaker
Ok, so if I would buy the PWM dimming expansion module, I can connect the Jebao cable from your store without modifying ? Am I correct ?
I think that would be better in case I need more pumps or lights.
Thanks in advance.
Leslie
Thanks in advance.
Leslie
Correct. You can use with the standard Jebao cable without any modification.
lmolenmaker
I received the dimming expansion module. I want to connect my Jebao pump with your cable to the expansion.
Do I have to cut off the connector and connect the red wire to one of the 5 ports on the left and the black wire to one of the three ports on the right?
Thanks in advance.
Leslie
ps Happy New year !
Thanks in advance.
Leslie
ps Happy New year !
