error uploading
Rita
error uploading
Post by Rita »
I can't upload my ino file. It says "error uploding"
This is it:
Watchdog Timer
Version Menu
Simple Menu
Dimensione del file binario dello sketch: 11.212 bytes (su un massimo di 32.256 bytes)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM3 -b115200 -D -V -Uflash:w:C:\Users\Gretaaa\AppData\Local\Temp\build4502478065828484044.tmp\sketch_dec17b.cpp.hex:i
Using Port : \\.\COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x64
avrdude done. Thank you.
Re: error uploading
Please check if you have the correct board selected under menu Tools->Board.
Rita
Re: error uploading
Post by Rita »
Yes it's the Classic reef Angel.
Rita
Re: error uploading
Post by Rita »
are there problems with windows 8? I use the wizard
Re: error uploading
I don't think there is any problems with W8.
Can you also make sure that you have the correct serial port selected?
Is the driver installed correctly for the usb-ttl cable?
