I'll give it a try. Thanks for the great work and Happy Holidays to tou too.
clw143
Post by clw143 »
Does the droid app have functionality for ATO alarm or overheat alarm to actually indicate that it is in alarm?
I can clear it via the app but there is no indication IF it needs cleared.
clw143 wrote:Does the droid app have functionality for ATO alarm or overheat alarm to actually indicate that it is in alarm?
Not currently. That functionality is possible with the latest version of the libraries but it's not implemented yet.
TanksNStuff
Post by TanksNStuff »
You do have the option to show ATO LOW and/or ATO HIGH status on the controller screen of the droid app. These will tell you if the float switch is activated (On) or not (Off).
What I do to check if ATO needs to be cleared is to check if the ATO relay switch is On or Off. If it's Off but the ATO LOW is On... then it needs to be cleared.
Sent from my DROID RAZR using Tapatalk
ReEfnWrX
Post by ReEfnWrX »
So today all of a sudden I was unable to update my Controller status on my app... I logged into the portal and was able to connect and receive updated information... I got home, via the local IP I can update the app... Via my external IP I cannot, whether connected to my home wifi or through 4G. I have restarted my phone, rebooted the controller, rebooted my router, verified my port forwarding and DHCP reservation (although the router doesnt seem to be the issue since I was always able to update via portal....
It seems like I am having an issue with the app specifically. Any ideas?
ReEfnWrX wrote:So today all of a sudden I was unable to update my Controller status on my app... I logged into the portal and was able to connect and receive updated information... I got home, via the local IP I can update the app... Via my external IP I cannot, whether connected to my home wifi or through 4G. I have restarted my phone, rebooted the controller, rebooted my router, verified my port forwarding and DHCP reservation (although the router doesnt seem to be the issue since I was always able to update via portal....
Hmm....what error was the app giving you? was it a timeout issue or a parser error? are you able to pull up the controller's internal web page (http://PUBLICIP:2000/wifi) from your phone on a web browser? i have noticed that sometimes the way the smart phones work, they are a little bit slower than our desktop/laptop companions.
If it is timing out with the connection, under the settings there is a section that you can adjust the timeout values and lengthen them. that "could" make a difference with your problems.
ReEfnWrX
Post by ReEfnWrX »
I've been using the App with no issues at all for about a month. I had increased the timeouts about two weeks ago to try to decrease the frequency of timeouts occurring...
Also, I just got an email from reeftronics. it is not getting a response from my Wifi either, they stopped logging so it is not just the app... very strange.....
ReEfnWrX wrote:I've been using the App with no issues at all for about a month. I had increased the timeouts about two weeks ago to try to decrease the frequency of timeouts occurring...
yes, that is strange indeed.
ReEfnWrX
Post by ReEfnWrX »
Definitely not the App... My IP changed... which is weird, it typically changes two or 3 times max a year... and it just changed a month and a half ago... strange.. Maybe I need to figure out a good dyn DNS service
Binder;
I have a request for the next update of the app.
It it possible to display the mode that the DC pumps are running in.
IE ReefCrest, Logoon, Tidal Swell...
Sacohen wrote:Binder;
Yes, I believe it should be possible. I can add it to my list of things to work on.
Great.
phrusher
Post by phrusher »
Any thoughts on switching to Android Studio instead of eclipse? :)
phrusher wrote:Any thoughts on switching to Android Studio instead of eclipse? :)
actually yes. I have looked into it a little but haven't had the chance or time to make the switch. I am also in the process of removing the usage of the 2 external library dependencies. :-)
Sent from my Nexus 7
phrusher
Post by phrusher »
Ok, so you are planning to up the lowest version? 4.1+?
phrusher wrote:Ok, so you are planning to up the lowest version? 4.1+?
no. I'm still planning on keeping it in the 2.3 version. if I recall, I can still do that by using the compat libraries.
pandimus
Post by pandimus »
What is the cause of the error 11?
pandimus wrote:What is the cause of the error 11?
It has something to do with the URL. It can come from the controller terminating the connection too quickly or there was an input/output error reading from the controller.
Theres a flush buffer or something that you should make sure is big enough. I forget the parameter but that took care of it when it was affecting the iphone app.
pandimus
Post by pandimus »
Is odd because I get it, then it refresh and then connection is fine. So that can be fixed on my controller side of app side?
pandimus
Post by pandimus »
I've constantly got error 11 and error 15 on my notifications
pandimus wrote:Is odd because I get it, then it refresh and then connection is fine. So that can be fixed on my controller side of app side?
i get it at times too. try setting the error refresh to 2 or 3 and have the retry interval to 5 or 10 seconds.
Sent from my Moto X
pandimus
Post by pandimus »
Sent from my Moto X
Done I'll see how it works out..
wtitb
Post by wtitb »
Hi,
what a great app! Many many thanks for it. I'm using it with an old android phone as a "remote" for the RA mounted directly on the wall behind my tank. Today I've found the notifications in your app, another great thing. I was wondering if one could setup the ringtone for the notifications to be continous? So it would be a nice replacement for the buzzer.
cheers,
Christian
wtitb wrote:Hi,
cheers,
Christian
I'm not sure if I could set that feature up. I will have to look into continuous notification sounds and see what all it requires.
wtitb
Post by wtitb »
many thanks for trying it! :)
Just because you aren't busy enough. :D
I would love to see a re-design of the relay pages so they were more like the commands page. I.e., big square buttons.
cosmith71 wrote:Just because you aren't busy enough. :D
haha...yeah, i've not liked the relay pages for a while now and have been wanting to do something "better" for them. still haven't come up with anything better yet.
Ademster
Post by Ademster »
Short of deleting the app, and starting over. How can I get the expansion Relay deleted off the main page?
I have disabled it in the settings page. As soon as I go back to the main screen and flip the pages, it is still there!
Adam
58 Gal
Ademster wrote:Short of deleting the app, and starting over. How can I get the expansion Relay deleted off the main page?
make sure you uncheck "auto update modules".
Sent from my Moto X
