Reset Reef Angel via the web
My Reef Angel seems to get into a state where the screen is all white. It seems to happen whenever the ATO timeout occurs. Is there a way to remotely reset the device without pulling the plug or reloading the software (via web command)?
Re: Reset Reef Angel via the web
You can do with the latest libraries.
You can use /boot command
Does this work with the 1.0.9 libraries? The new ones are too big for my old Reef Angel
You have just made me spend $75 on upgrading. Thanks Roberto...
The latest version of the Andriod App has a reboot button on the 1st screen, but I guess you would need the current libraries in order for it to work.
It's nice to have the extra memory. I've always recommended people to get the plus.
I've been debating for quite a while. I'd like to you use the SunLocation class and the WiFi Alert. Now I will.
Go with the Plus. The new libraries are getting too big to even put on the standard RA.
I concur! Plus it lets you geek out when you have no other projects to work on =pSacohen wrote:Go with the Plus. The new libraries are getting too big to even put on the standard RA.
When are there no other projects to work on.
I constantly have 3-4 going and just work on the one I feel like at the time or the one that has to be done before I can go onto the one I want to do.
Just upgraded. It is SOOO much easier to get a build to fit!
Anyone want to buy a regular ReefAngel board??? LOL...
