Check library version fails
PostPosted: Fri Jan 03, 2014 11:15 am
Hi everyone. New computer and it came with windows 8.1 but this was working on my 7 box which went kaput. Anyway, trying to connect back up to my Reef Angel and running into some errors. I have the Reef Angel Client working which is great. However, when I try to use the Arduino Reef Angel client to load my last saved sketch it is throwing me an error like below. It compiles fine but if I try and do something simple has check latest version of development libraries (which is what, 1.10 now? I'm on 1.09) it fails.
Any ideas? It did have me download and install a new version of Arduino which is 1.0 5 I believe.
Thanks.
-scott
Exception in thread "AWT-EventQueue-0" java.lang.NoSuchMethodError: processing.app.Editor.getBase()Lprocessing/app/Base;
at template.tool.RALibsVer.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
PostPosted: Fri Jan 03, 2014 11:37 am
Try deleting or renaming the folder Documents\Arduino
Then, download a fresh copy of the Reef Angel Installer from the website and install it again.
PostPosted: Fri Jan 03, 2014 11:49 am
rimai wrote:Try deleting or renaming the folder Documents\Arduino
Ok, let me give that a shot. Was thinking of that but didn't try it. Be back in a few.
Thanks Rimai. That appears to have done the trick. I'm not sure why it failed the first time or didn't install correctly but the re-install took care of it. The only thing maybe is that I left the USB cable connected but I thought it wasn't. Anyway, thanks.
