RA status log
PostPosted: Sat Jan 04, 2014 12:48 pm
I checked the log and it's not recording the pH. Does anybody else have this problem?
PostPosted: Sat Jan 04, 2014 3:05 pm
Your banner which you have wrong in your signature shows that your ph is 8.04
You need to add [ img ] tags around it [ /img ] (take away the spaces between the brackets. )
PostPosted: Sat Jan 04, 2014 4:50 pm
Thanks for the heads up on how to fix my signature. I have been meaning to fix that. On my phone it logs temp but not pH using the RA Status app.
PostPosted: Sat Jan 04, 2014 5:05 pm
Which RA Status app? For Android or iPhone?
PostPosted: Sat Jan 04, 2014 6:59 pm
For Android.
PostPosted: Sat Jan 04, 2014 7:20 pm
That is strange, everything on the Android App has been working wonderfully for me...
Is it displaying the pH level on your RA display itself?
PostPosted: Mon Jan 06, 2014 10:51 am
the value should show on the Android screen unless you have turned off (hidden the visibility) of the ph. check the controller settings and then visibility and make sure ph is checked.
if you view the history, it only shows the temperature values in the list but if you tap on the entry it brings up a window that shows all the values except the relays.
hopefully that helps a little.
Sent from my Nexus 7
PostPosted: Thu Jan 09, 2014 6:52 pm
binder wrote:the value should show on the Android screen unless you have turned off (hidden the visibility) of the ph. check the controller settings and then visibility and make sure ph is checked.
The pH is set to display. I can see the pH when I click on each individual time parameters are recorded. I would like to see how it changes over time.
Return to Apps
Users browsing this forum: Google [Bot] and 0 guests
