This morning I woke up to a warm morning. I noticed that my fans were not on. I checked the alert on the controller and I noticed the following:
• Date was set to 03/19/43
• Bus lock on
• Ato timeout (due to waterlevel reading 0)
After a quick search on the forum, I figured out that it has something to do with the USB hub.
There are two expansions connected to the hub at the moment:
• PWM Dimming Expansion Module
• Waterlevel Expansion
I disconnected the cables and plugged in the PWM, no problems here.
Then I plugged in the Waterlevel, now the Controller gives the Bus lock alert. (I took out the PWM cable beforehand)
So something is wrong with the Waterlevel expansion, so I thought. I connected the Waterlevel cable directly to the relay box and all is working fine. So now I think something is wrong with the expansion hub.
Can somebody help me out here and explain why there is a bus lock?
Also when I try to connect the data cable to my laptop for uploading, more often than not, my computer says that it cannot recognise the USB device, which makes it very hard to upload things. Any help with this is also much appreciated.
Thanks in advance,
Leslie
InternalMemory.OverheatTemp_write( 500 );
// ReefAngel.DCPump.ActinicChannel=Sync; // Now you're pump will be affected by the portal settings.
ReefAngel.UseFlexiblePhCalibration(); // Calibration for ph4 and ph7 via controller
// Ports that are always on/off
ReefAngel.Relay.Off(Port5);
ReefAngel.StandardFan( Port1,250,255 );
ReefAngel.StandardLights( Port2,9,0,23,00 );
//ReefAngel.StandardLights( Port3,10,30,22,30 );
ReefAngel.StandardLights( Port4,19,0,19,1 );
ReefAngel.StandardHeater( Port7,245,250 );
//ReefAngel.DCPump.SetMode( ShortPulse,90,165 );
//ReefAngel.DCPump.DaylightChannel = None;
//ReefAngel.DCPump.ActinicChannel = Sync;
// ReefAngel.DCPump.UseMemory=true; // Use whatever is in the portal
if (millis() > 1000) // After 1 second
if ( (hour() >=18) && (hour() <20) )
ReefAngel.Relay.Off(Port5); // Freshwater ATO off between 18.00 and 20.00, port 5
ReefAngel.WaterLevelATO(Port5,30,95,99); // else min level 95% and max level 99%, timeout 30 sec
if ( (hour() >=18) && (hour() <19) )
ReefAngel.WaterLevelATO(Port6,4000,96,99); // Saltwater ATO on when below 96%, max level 99%, timeout 4000 sec. Port 6 between 18.00 and 19.00
ReefAngel.Relay.Off(Port6); // otherwise port 6 off
ReefAngel.CustomVar[1]=ReefAngel.Relay.Status(Port1); // Fan on email trigger
ReefAngel.CustomVar[4]=ReefAngel.Relay.Status(Port4); // Alk on email trigger
ReefAngel.CustomVar[5]=ReefAngel.Relay.Status(Port5); // Freshwater on email trigger
ReefAngel.CustomVar[7]=255;
if ( hour()>=10 && hour()<22)
ReefAngel.PWM.SetDaylight( PWMParabola(10,0,22,0,0,35,0) );
ReefAngel.PWM.SetActinic( PWMParabola(10,0,22,0,12,50,0) );
ReefAngel.PWM.SetActinic( PWMSlope(9,0,23,0,0,12,60,0) );
ReefAngel.PWM.SetDaylight(0);
if ( (hour() >=10) && (hour() <23) )
if ( (hour() >=10) && (hour() <12) )
ReefAngel.DCPump.SetMode( ShortPulse,90,50); // shortpulse 90% 50 millisec, 10 - 12
ReefAngel.DCPump.ExpansionChannel[0] = Sync;
if ( (hour() >=12) && (hour() <13) )
ReefAngel.DCPump.SetMode( Constant,90,200); // Constant 90%, 12 - 13
if ( (hour() >=13) && (hour() <16) )
ReefAngel.DCPump.SetMode( ShortPulse,90,50); // shortpulse 90%, 50 millisec, 13 - 16
if ( (hour() >=16) && (hour() <17) )
ReefAngel.DCPump.SetMode( Constant,90,200); // Constant 90%, 16 - 17
if ( (hour() >=17) && (hour() <20) )
ReefAngel.DCPump.SetMode( ShortPulse,100,50); // shortpulse 100%, 50 millisec, 17 - 20
if ( (hour() >=20) && (hour() <21) )
ReefAngel.DCPump.SetMode( Constant,90,200); // Constant 90%, 20 - 21
if ( (hour() >=21) && (hour() <23) )
ReefAngel.DCPump.SetMode( ShortPulse,100,200); // Shortpulse 100%, 200 millisec, 21 - 23
ReefAngel.DCPump.SetMode( Constant,70,150); // otherwise Shortpulse, 70%, 150 millisec
ReefAngel.Portal( "lmolenmaker" );
