RA+ and expansion Hub malfunctioning !
lmolenmaker
Post by lmolenmaker »
Hi Guys,
This morning I woke up to a warm morning. I noticed that my fans were not on. I checked the alert on the controller and I noticed the following:
• Date was set to 03/19/43
• Bus lock on
• Ato timeout (due to waterlevel reading 0)
After a quick search on the forum, I figured out that it has something to do with the USB hub.
There are two expansions connected to the hub at the moment:
• PWM Dimming Expansion Module
• Waterlevel Expansion
I disconnected the cables and plugged in the PWM, no problems here.
Then I plugged in the Waterlevel, now the Controller gives the Bus lock alert. (I took out the PWM cable beforehand)
So something is wrong with the Waterlevel expansion, so I thought. I connected the Waterlevel cable directly to the relay box and all is working fine. So now I think something is wrong with the expansion hub.
Can somebody help me out here and explain why there is a bus lock?
Also when I try to connect the data cable to my laptop for uploading, more often than not, my computer says that it cannot recognise the USB device, which makes it very hard to upload things. Any help with this is also much appreciated.
Thanks in advance,
Leslie
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    InternalMemory.OverheatTemp_write( 500 );
 //   ReefAngel.DCPump.ActinicChannel=Sync; // Now you're pump will be affected by the portal settings.
      ReefAngel.UseFlexiblePhCalibration();    // Calibration for ph4 and ph7 via controller
    // Ports that are always on/off
      ReefAngel.Relay.Off(Port5);
    ReefAngel.StandardFan( Port1,250,255 );
    ReefAngel.StandardLights( Port2,9,0,23,00 );
    //ReefAngel.StandardLights( Port3,10,30,22,30 );
    ReefAngel.StandardLights( Port4,19,0,19,1 );
    ReefAngel.StandardHeater( Port7,245,250 );
    //ReefAngel.DCPump.SetMode( ShortPulse,90,165 );
    //ReefAngel.DCPump.DaylightChannel = None;
    //ReefAngel.DCPump.ActinicChannel = Sync;
   // ReefAngel.DCPump.UseMemory=true;                 // Use whatever is in the portal
      if (millis() > 1000)                                      // After 1 second
    if ( (hour() >=18) && (hour() <20) )
      ReefAngel.Relay.Off(Port5);                               // Freshwater ATO off between 18.00 and 20.00, port 5
      ReefAngel.WaterLevelATO(Port5,30,95,99);                  // else min level 95% and max level 99%, timeout 30 sec
    if ( (hour() >=18) && (hour() <19) )
      ReefAngel.WaterLevelATO(Port6,4000,96,99);                // Saltwater ATO on when below 96%, max level 99%, timeout 4000 sec. Port 6 between 18.00 and 19.00
      ReefAngel.Relay.Off(Port6);                               // otherwise port 6 off
      ReefAngel.CustomVar[1]=ReefAngel.Relay.Status(Port1);    //  Fan on email trigger
      ReefAngel.CustomVar[4]=ReefAngel.Relay.Status(Port4);    // Alk on email trigger
      ReefAngel.CustomVar[5]=ReefAngel.Relay.Status(Port5);    // Freshwater on email trigger
      ReefAngel.CustomVar[7]=255;
       if ( hour()>=10 && hour()<22)
       ReefAngel.PWM.SetDaylight( PWMParabola(10,0,22,0,0,35,0) );
       ReefAngel.PWM.SetActinic( PWMParabola(10,0,22,0,12,50,0) );
       ReefAngel.PWM.SetActinic( PWMSlope(9,0,23,0,0,12,60,0) );
       ReefAngel.PWM.SetDaylight(0);
   if ( (hour() >=10) && (hour() <23) )
      if ( (hour() >=10) && (hour() <12) )
      ReefAngel.DCPump.SetMode( ShortPulse,90,50);              // shortpulse 90% 50 millisec, 10 - 12
      ReefAngel.DCPump.ExpansionChannel[0] = Sync;
    if ( (hour() >=12) && (hour() <13) )
            ReefAngel.DCPump.SetMode( Constant,90,200);          //  Constant 90%, 12 - 13
    if ( (hour() >=13) && (hour() <16) )
            ReefAngel.DCPump.SetMode( ShortPulse,90,50);              // shortpulse 90%, 50 millisec, 13 - 16
    if ( (hour() >=16) && (hour() <17) )
            ReefAngel.DCPump.SetMode( Constant,90,200);          //  Constant 90%, 16 - 17
    if ( (hour() >=17) && (hour() <20) )
            ReefAngel.DCPump.SetMode( ShortPulse,100,50);                // shortpulse 100%, 50 millisec, 17 - 20
    if ( (hour() >=20) && (hour() <21) )
            ReefAngel.DCPump.SetMode( Constant,90,200);          //  Constant 90%, 20 - 21
    if ( (hour() >=21) && (hour() <23) )
            ReefAngel.DCPump.SetMode( ShortPulse,100,200);          //  Shortpulse 100%, 200 millisec, 21 - 23
            ReefAngel.DCPump.SetMode( Constant,70,150);          // otherwise Shortpulse, 70%, 150 millisec
    ReefAngel.Portal( "lmolenmaker" );
Re: RA+ and expansion Hub malfunctioning !
Does this happen on different ports of the hub too?
lmolenmaker
Hi Roberto,
Yes, I tried different ports on the hub as well. I also switched the usb cables between the pwm and waterlevel and expansion hub as well with no luck.
Let me try to understand better.
Does it work correctly when you have this connected:
1. Only hub
2. Hub and WL
3. Hub and dimming
4. Hub, dimming and WL
lmolenmaker
1. RA is working correctly
2. Waterlevel Not working
3. PWM working
4. Waterlevel not working, PWM working
So it seems the combination WL and Hub is NOT working.
Combination WL and relaybox is working correctly.
That's weird, how it works by itself but not with the hub :?
I'm assuming it was working and it stopped??
Send me a PM and we RMA this module.
lmolenmaker
Did you receive the PM (i am not sure if I did it correctly, first time i used PM), message stays in "outbox" folder, not in "sent messages" folder.
Leslie
lmolenmaker
Do you also have a solution or suggestion for the second part of the problem? (see first post)
Sometimes my laptop doesn't recognise the USB device.
I look forward hearing from you.
Leslie
Is it plugged in properly?
Did you try a different USB port?
What does it do when you plug the cable?
Does this happen on different computers?
