I just setup my dimming expansion, and moved my lights over to it in channels 0&1. Now when I use the lights on command it won't work because of not knowing where to dim. How do I modify?
Sent from my SCH-I535 using Tapatalk
Dimming expansion
Re: Dimming expansion
Which port is your drivers connected to?
Or what do you have for ReefAngel.LightsOnPorts ??
chapboogie
My lights are now in channels 0&1 of the expansion. The sketch shows lights on ports= Port5bit and Port6bit
Try this:
if (ReefAngel.Relay.isMaskOn(Port6))
ReefAngel.PWM.SetChannel(0,50);
ReefAngel.PWM.SetChannel(1,50);
chapboogie
I don't know where to put this. This is my first edit from something that was made in the wizard.
chapboogie
This is my sketch
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit;
ReefAngel.LightsOnPorts = Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit | Port5Bit;
InternalMemory.OverheatTemp_write( 843 );
ReefAngel.Relay.On( Port7 );
ReefAngel.Relay.DelayedOn( Port2,10 );
ReefAngel.SingleATO( true,Port3,2000,0 );
ReefAngel.StandardHeater( Port4,796,814 );
ReefAngel.StandardLights( Port5,13,0,23,0 );
ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.PWM.SetChannel( 0, PWMParabola(13,0,23,0,9,75,9) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(13,30,22,30,9,54,9) );
ReefAngel.PWM.SetChannel( 2, MoonPhase() );
ReefAngel.DCPump.SetMode( ReefCrest,90,10 );
ReefAngel.DCPump.DaylightChannel = AntiSync;
ReefAngel.DCPump.ExpansionChannel[0] = None;
ReefAngel.Portal( "chapboogie" );
See the comments where it says place your custom code above and below here? Thats where it goes.
chapboogie
It works now. Thanks a bunch. So much I want to tackle soon.
