- image.jpg (274.01 KiB) Viewed 10484 times
My RA+ setup
Re: My RA+ setup
Slightly better wire management. Got to improve.
Re: My RA+ setup
What is the dc pump controller for?
Sent from my SCH-I535 using Tapatalk
Re: My RA+ setup
What's the unit above the wifi module? I don't recognise it and can't find it in the store.
Re: My RA+ setup
That is the controller for Jebao DC6000 pump. I use it as a return pump in the sump.chapboogie wrote:What is the dc pump controller for?
Re: My RA+ setup
That's the Bluetooth module. Not in the store as yet. Roberto might still have some left. Uploading code is a breeze with this module.bubbles wrote:What's the unit above the wifi module? I don't recognise it and can't find it in the store.
Re: My RA+ setup
Ooooh! Might want to add that to the collectiondavaraj wrote:That's the Bluetooth module. Not in the store as yet. Roberto might still have some left. Uploading code is a breeze with this module.bubbles wrote:What's the unit above the wifi module? I don't recognise it and can't find it in the store.
Re: My RA+ setup
Setup might much better dave.
bubbles the bluetooth module is great you can wirelessly upload your code and if you have a connection to you computer like Teamviewer or something you can remote into you computer and upload code while you are not even at home.
