Thavngr98 code
Thavngr98
Thavngr98 code
Post by Thavngr98 »
I've lost my code one to many times. Finally adding it here
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit |
Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardATO(Port1,2700);
    ReefAngel.DayLights( Port2 );
    ReefAngel.MoonLights( Port4 );
    ReefAngel.StandardHeater( Port6 );
    ReefAngel.StandardLights( Port7,02,00,6,00);
    if(hour()==7 && minute()==55 && second()==0)
ReefAngel.FeedingModeStart();
    if(hour()==18 && minute()==55 && second()==0)
    if (hour()<17)
    ReefAngel.StandardLights(Port4,13,00,14,20);
    ReefAngel.StandardLights(Port4,21,30,23,00);
    ReefAngel.Portal( "thavngr98" );
-Dave
Thavngr98
Re: Thavngr98 code
Post by Thavngr98 »
Added WP40 short pulse and 30% overnight
        if (hour()<17)
    ReefAngel.PWM.SetActinic( ShortPulseMode(0,80,4,true));
        if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(0);
        if (hour()<7) ReefAngel.PWM.SetActinic(30);
-Dave
Re: Thavngr98 code
Your night/feeding mode code has to come after you set the wp40 default or it will always be overriden by the default mode.
Thavngr98
Re: Thavngr98 code
Post by Thavngr98 »
lnevo wrote:Your night/feeding mode code has to come after you set the wp40 default or it will always be overriden by the default mode.
So this way?
           if (hour()<7) ReefAngel.PWM.SetDaylight(30);
Or do you mean my whole feeding code?
    //Reefbrite mode
    //WP40 mode
    //Feed mode AM and PM
        if (hour()<17)
     //WP40 30% overnight
-Dave
Re: Thavngr98 code
Just the first part.
But you have it going to 30% on the daylight channel and default/feeding on the actinic...is that what you wanted?
Thavngr98
Re: Thavngr98 code
Post by Thavngr98 »
lnevo wrote:Just the first part.
Nice catch. thanks! So would this work?
            if (hour()<17)
-Dave
Thavngr98
Re: Thavngr98 code
Post by Thavngr98 »
    //ReefAngel.PWM.SetActinic( LongPulseMode(0,50,5,true));
   // ReefAngel.PWM.SetActinic( ReefCrestMode(0,45,10,true));
        if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
        if (hour()<17)
//Custom Main, Graph & Menu
      byte x;
      byte y = 2;
      char text[7];
      // *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
      int TempColor;        // Color for drawing temperature
      boolean FanOn = ReefAngel.Relay.Status(Port5);    // Get the status of the fan relay
      boolean HeatOn = ReefAngel.Relay.Status(Port6);   // Get the status of the heater relay
      if (HeatOn)
        TempColor = COLOR_NAVY;    // Blue text, too cold, heater is on
      if (FanOn)
          TempColor = COLOR_RED;   // Red text, too warm, fan is on
      if (!HeatOn && !FanOn)
          TempColor = COLOR_GREEN;  // Green text, no fan or heater on
      ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_BLACK, 0, 1, "    Dave's Reef     ");    // Put a banner at the top
      ReefAngel.LCD.DrawDate(6, 119);                                                      // Put the date and time at the bottom
      pingSerial();        // Hit the Wifi Attachment
      x = 12;
      y += MENU_START_ROW+1;                                                               // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
      ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Tank Temp     pH");
      ConvertNumToString(text, ReefAngel.Params.PH, 100);                                  // Get pH reading and convert
      ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16);    // Put pH on the screen
      ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10);                       // Get T1 temp and convert
      y += MENU_START_ROW*2;
      x = 10;
      ReefAngel.LCD.Clear(TempColor, x, y-1, x+63, y-1);                                   // Draw a line above and below the temp
      ReefAngel.LCD.Clear(TempColor, x, y+16, x+63, y+16);                                 // To make it look nicer and easier to read
      ReefAngel.LCD.DrawHugeNumbers(COLOR_WHITE, TempColor, x, y, text);                   // Draw the temperature, white numbers on a colored background
      x += (16*4) + 8;
      //ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,8,y+25,"White %");
      //ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, 24, y+35, 1);    // Draw the white light %
      ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+8,y+25,"Blue %");
      ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+24, y+35, 1);   // Draw the blue light %
      ReefAngel.LCD.Clear(COLOR_BLACK,5,y+22,127,y+22);                                    // Draw a box around the light area
      ReefAngel.LCD.Clear(COLOR_BLACK,5,y+22,5,y+46);                                      //
      ReefAngel.LCD.Clear(COLOR_BLACK,127,y+22,127,y+46);                                  //
      ReefAngel.LCD.Clear(COLOR_BLACK,5,y+46,127,y+46);                                    //
      // Code for drawing the relay box
      ReefAngel.LCD.DrawOutletBox(14, 92, TempRelay);
-Dave
Thavngr98
Re: Thavngr98 code
Post by Thavngr98 »
Lights Removed
        ReefAngel.OverheatShutoffPorts = Port1Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
        ReefAngel.Relay.On( Port2 );
        ReefAngel.StandardATO( Port1,2700);
        ReefAngel.StandardFan( Port5 );
        ReefAngel.StandardLights( Port7,01,00,6,00);
        ReefAngel.StandardLights(Port4,16,30,17,45);
        ReefAngel.StandardLights(Port4,21,30,23,45);
        //Wave patterns
        if (hour()>=24 && hour()<8)
          ReefAngel.PWM.SetActinic( LongPulseMode(40,40,10,true) ); // Long pulse at 40% with 10s pulse
        else if (hour()>=8 && hour()<11)
          ReefAngel.PWM.SetActinic( TidalSwellMode(50,true) ); // Tidal Swell at 40%
        else if (hour()>=11 && hour()<12)
          ReefAngel.PWM.SetActinic( ReefCrestMode(50,20,true) ); // ReefCrest at 50% + - 20
        else if (hour()>=12 && hour()<13)
          ReefAngel.PWM.SetActinic( ShortPulseMode(0,70,4,true)); // Short Pulse 70%
        else if (hour()>=13 && hour()<14)
          ReefAngel.PWM.SetActinic( ReefCrestMode(70,20,true) ); // ReefCrest at 70% + - 20
        else if (hour()>=15 && hour()<18)
          ReefAngel.PWM.SetActinic( millis()%1000>800?80:0); // Wave
        else if (hour()>=18 && hour()<21)
          ReefAngel.PWM.SetActinic( NutrientTransportMode(55,70,3000,true) ); //   Nutrient Transport
        else if (hour()>=21 && hour()<24)
          //Turn Off during feed mode
          //Feed Modes 7:55am and 6:55pm
          //if(hour()==7 && minute()==55 && second()==0)
          //  ReefAngel.FeedingModeStart();
            if (hour()<17)
          byte x;
          byte y = 2;
          char text[7];
          if (HeatOn)
          if (FanOn)
          x = 12;
          x = 10;
          x += (16*4) + 8;
-Dave
Re: Thavngr98 code
What did you replace them with?
Thavngr98
Re: Thavngr98 code
Post by Thavngr98 »
taking them off the controller. They keep tripping my gfci every now and then except the last time (2 days ago) I lost all but 1 fish and about half my coral
-Dave
Re: Thavngr98 code
That sucks man. Sorry to hear. I'll hook you up with some frags next time I do some trimming...
Thavngr98
Re: Thavngr98 code
Post by Thavngr98 »
thats very thoughtful. thanks
-Dave
