power strip ?
aqua man 07
power strip ?
a friend of mine has a used Reef angel for sale can I use the power strip off of another unit to add to mine?
aqua man 07
Re: power strip ?
OK will I be able to use the dimming on it
Re: power strip ?
Not on the one that is on the relay exp. but if the new one is analog and your current is pwm (or vice versa) you could switch which is main and which is expansion...
aqua man 07
Re: power strip ?
Can just the expansion module be purchased without the relay power strip?
aqua man 07
Re: power strip ?
Will do as soon as I get the other unit thanks.
