Timer for UV
Ask in here.
ishtak
Timer for UV
Post by ishtak »
Hi boffins,
How would I set an on/off timer for a UV light .. ie 6 hours on 6 hours off
Justin
Pny
Re: Timer for UV
Post by Pny »
I would leave it on, unless you have problem with the heat it generates... Turning on/off of any electrical product tend to reduce their life span.
200 liter reef cube + 1000 liter FOWLR
Re: Timer for UV
ReefAngel.Relay.Set(Port7, now()%43200<21600);
Re: Timer for UV
For the record and to help people understand. The above command sets the port to On/Off based on the conditional.
The now()%43200 part divides the current time in seconds by 12 hours. If the remainder is less than 6 hours than the port will be on. If it's greater than 6 hours it will be off.
ishtak
Re: Timer for UV
Post by ishtak »
Thanks Lee .. Pny, I've been told that if you run pellets then it is better to not run UV constantly.
Smotz
Re: Timer for UV
Post by Smotz »
Hers's mine
//  Only turn on UV Sterilizer between 11pm and 4am
    if ( (hour() >= 4) && (hour() < 23) )  // from 4a - 11p
    ReefAngel.Relay.Off(UVlight);
    else ReefAngel.Relay.On(UVlight);
