I remember this was mentioned a while back and I see the modes defined to turn on/off the Vortech drivers. What I don't recall was whether or not this required a firmware update to support them or not.
Thanks in advance!
Vortech On/Off
Re: Vortech On/Off
Yes it does.
Re: Vortech On/Off
I can run the same command in the bat file on Linux? Do I need the avrdude.exe and avrdude.conf or the one from my Arudino install will be ok?
- Contact:
Re: Vortech On/Off
the one from arduino works just fine. you may have a slightly longer command due to the location not being in your PATH.
Re: Vortech On/Off
That part i knew (path-wise) just didnt know if anything specific i need in the conf file included...
