Hey guys,
I'm ready to submit my order for a Reef Angel Plus and modules but would like you guys to review it and make sure I'm not missing anything here.
My setup and plan is as such. I have my display tank overflowing into sump 1(20 gallon), which contains my protein skimmer and a Jebao DC1200 pump used to move the water to sump 2(40 gallon) containing my refugium, bubble trap, and another Jebao DC1200 pump to return back to the display tank.
I would like to use the Multi-Channel Water Level Expansion module and Dimming Expansion module to monitor and control the DC1200 speeds to keep the water levels at a set height.
I would like to control my two Jabeo wavemakers (WP-25 and WP-40) also with the Dimming Expansion module.
My Refugium LED light I would like to only turn on and off. Therefore I was planning on just plugging it into the relay outlet box.
Wi-Fi Module for remote access.
So here's my list:
Reef Angel +
Expansion Hub
Dimming Expansion
Wi-Fi module
Am I forgetting anything? Any other suggestions or comment? Thanks guys!
Josh
Yet another......What do I need post.
Re: Yet another......What do I need post.
I think you are missing the jebao cables... One per pump.
jgsplat
Thanks Roberto!
I have several cables that have the 3 pin connector on one and an exposed wires on the other. I was going to make my own custom cable to length. Which I guess leads me to the question of what do I need to terminate the other side of my cable with that connects to your dimmer module?
nothing... The dimming module has screw terminals
jgsplat
Perfect! That will sure make life easy. Thanks Roberto! I've also heard your local? I work in Milpitas and live in Fremont.
