ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.DelayedOn( Port1,1 );
ReefAngel.StandardHeater( Port6,778,781 );
ReefAngel.Relay.DelayedOn( Port7,1 );
ReefAngel.SingleATO(true,Port8,300,0);
if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port8);
ReefAngel.Portal( "Mhumbach" );
Screen stays backlit but is only black
Mhumbach
Hello, I am new here and have been loving my reef angel. Recently the screen blacks out but stays backlit, I can still control it from my phone and when I reboot the controller the screen turns back on. This is my code I believe.
Mhumbach
Re: Screen stays backlit but is only black
It stays black but the back light turns on. Im close to using up all of my memory the controller could that be triggering it?
Humm. Looks like you got a bad screen then.
PM me for RMA.
PM me for RMA.
