Help coding ATO
mrwlf
Help coding ATO
Post by mrwlf »
Hi i need help to generate a code for my old first generation Reef Angel.
Using wizard i generated this code that is almost ready for my needs except for the Ato.
I would like to use the two floating switches like this:
First as Ato that activate port 3 (and i did it with the wizard)
Second switch to Activate port 4 ti fill my water reservoir
How do i code it?
Here is my actual code
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit;
    ReefAngel.LightsOnPorts = Port2Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit;
    InternalMemory.OverheatTemp_write( 300 );
    ReefAngel.StandardHeater( Port1,245,255 );
    ReefAngel.StandardLights( Port2,9,0,19,0 );
    ReefAngel.SingleATO( true,Port3,60,0 );
    ReefAngel.Relay.DelayedOn( Port8,1 );
Re: Help coding ATO
Sorry, I didn't understand the concept.
How do you want to use the second switch?
Is it just like a second ATO for your water reservoir?
mrwlf
Re: Help coding ATO
Post by mrwlf »
Thanks for your help...
I'll need the second switch as ATO for my water reservoir but without Timeout.
Will this work?
ReefAngel.Relay.Set( Port4, ReefAngel.HighATO.IsActive());
Re: Help coding ATO
Yes :)
Sent from my Galaxy S3 using Tapatalk
mrwlf
Re: Help coding ATO
Post by mrwlf »
