bigger tank
bigger tank
Looking for some feedback
When I update my tank I will have to add a 3rd led, but must tanks have a brace there. I was thinking about the kessel A360. Any ideas how to deal with this.
I also understand that that light does not turn all the way off with dimming. Is that correct?
Last question
How big of a jebao pump for a 72 inch wide 150 to 200 gallon tank?
Riggeek
Last question
Riggeek
riggeek
Re: bigger tank
Multiple powerheads is always a better option... You get better coverage, and have redundancy if a power head fails..
I would recommend 2 WP40's for 150 or 200... Maybe a 3rd WP25 for the 200 for more coverage?
Re: bigger tank
I agree with ReEfnWrX multiple powerheads is always better than a single and 2 40's should be plenty of movement for that size tank.
Re: bigger tank
I hope they are WP10's lol
I just got my WP25 last week, waiting on Jebao cable. I may actually buy 3 more wp25's and take out the wp40... I was dumb founded at the size difference.....
Re: bigger tank
Yeah, there's quite a diffence in size between the pumps.
Re: bigger tank
I saw the size in another post. WP-10 are so tiny. They didn't have them when I bought my samples.
I use 2x WP-25 and 2x MP-10
They are usually WP-25 at 50% and MP-10 at 70% on long pulse 2 minutes duration sync/antisync scheme and for a couple hours a day, when the lights peak, they go into short pulse at 100%.
Except for the 2nd MP-10 that just quit on me a few weeks back.
I was going to buy a new dry side but someone told me to just use a knife to open the seal and change the bearings, but I didn't have time yet.
Re: bigger tank
I have an MP-40 dry side that needed the bearings replaced. I screwed up the magnet trying to get them off since I didn't have the right tools. If you do, lmk, I have another drive shaft and the replacement bearings if you have the right stuff to do the swap lmkrimai wrote:I saw the size in another post. WP-10 are so tiny. They didn't have them when I bought my samples.
Re: bigger tank
Thanks for the info everyone.
Does each pump need it own analog control our will they run of the same pwm output with the adaptor for reefangel?
riggeek
Re: bigger tank
Technically, you can connect more than one in the same channel, but they would be running the same wave form.
Sent from my Galaxy S3 using Tapatalk
