i have the .19 release.
i change the value 812 memory trought the java client of Curt. i set it to 2 and i see that is at 2.
But when the function start :
ReefAngel.DosingPump(Port3, 1, 23, 00, InternalMemory.DP1Timer_read());
the on status don't run for 2 seconds, but for 6 seconds.
Why ? is changed somethings ?
Thanks a lot.
Problem with Dosometric
lukeluke
- Contact:
Re: Problem with Dosometric
Nothing has changed. If it runs for longer than desired, there could be other stuff in your PDE file that are taking longer to run than that function should run for. Every time the function is called, it checks if it should run or not. Could you post your PDE file for review to see if we can reproduce the problem and see if anything else is affecting it?lukeluke wrote:i have the .19 release.
Thanks a lot.
lukeluke
on my office's pc, i have only this my pde:
in the latest i change the PWM because i use the MH now .....
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
int DP3_Timer = InternalMemory.DP1Timer_read() * 4;
//Disegno schermo principale
// Change the 30 to adjust the horizontal position of the text on the screen, max 20-21 chars
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 15, 15, "LukeLuke's Cube");
ReefAngel.LCD.DrawMonitor(15, 35, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 6, 70, "DP1:");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 31, 70, InternalMemory.DP1Timer_read());
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 46, 70, "DP2:");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 71, 70, InternalMemory.DP2Timer_read());
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 86, 70, "DP3:");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 111, 70, DP3_Timer);
// draw main relay
ReefAngel.LCD.DrawOutletBox(12, 87, TempRelay);
#ifdef RelayExp
// draw 1st expansion relay
ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
#endif // RelayExp
void ConvertNumToString(char* string, int num, byte decimal)
char temptxt[3];
int Temp = num;
if (Temp==0xFFFF) Temp=0;
itoa(Temp/decimal,string,10);
if (decimal>1)
itoa(Temp%decimal,temptxt,10);
strcat(string, ".");
if (Temp%decimal<10 && decimal==100) strcat(string, "0");
strcat(string, temptxt);
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawDate(6, 2);
x = 12;
y += MENU_START_ROW+4;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),DPColor, x, y, 1);
t = intlength(ReefAngel.PWM.GetDaylightValue()) + 1;
t *= 5;
ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x+t, y, "%");
t += 10;
x += t;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x, y, 1);
t = intlength(ReefAngel.PWM.GetActinicValue()) + 1;
t *= 5;
ReefAngel.LCD.DrawText(APColor, DefaultBGColor, x+t, y, "%");
t += 10;
x += t;
char text[7];
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y, x+45, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+16, y, text,Font8x16);
ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(16*4),y+16);
ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y, text);
x += (16*4) + 8;
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,x,y,"T2:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, T2TempColor, x+18, y, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x,y+10,"T3:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, T3TempColor, x+18, y+10, 10);
y += 16*2;
x = 8;
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x, y, "DP1:");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+25, y, InternalMemory.DP1Timer_read());
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+37, y, "DP2:");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+62, y, InternalMemory.DP2Timer_read());
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+75, y, "DP3:");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+101, y, DP3_Timer);
x = 6;
y += MENU_START_ROW+6;
y -= 3;
ReefAngel.LCD.Clear(COLOR_BLACK, x, y, 124, y);
y +=1;
ReefAngel.LCD.Clear(COLOR_BLUE, x+1, y, 123, y+10);
y +=11;
ReefAngel.LCD.Clear(COLOR_BLACK, x, y-11, x, y+16);
ReefAngel.LCD.Clear(COLOR_BLACK, 124, y-11, 124, y+16);
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_BLUE, x+40, y-9, "Alarms");
y += 6;
x += 2;
byte fcolor;
// This is for the LOW Ato switch
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+2, y,"ATO:");
if ( InternalMemory.read(700) == 1 )
// add in InternalMemory.write(700, 1) when ato is tripped
// add in InternalMemory.write(700, 0) when ato is cleared
fcolor = COLOR_RED;
ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+30, y, "YES");
fcolor = COLOR_GREEN;
ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+30, y, "NO ");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+55, y,"OverH:");
if ( InternalMemory.read(701) == 1 )
// add in InternalMemory.write(701, 1) when overheat is tripped
// add in InternalMemory.write(701, 0) when overheat is cleared
fcolor = COLOR_RED;
strcpy(text, "YES");
strcpy(text, "NO ");
ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+94, y, text);
ReefAngel.LCD.Clear(COLOR_BLACK, x-2, y+11, 124, y+11);
x = 12;
y += 18;
// ReefAngel.LCD.DrawGraph(5,50);
ReefAngel.SetTemperatureUnit(1); // set to Celsius Temperature
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
//WifiAuthentication("lukeluke:Luca123");
// Set the ports that get toggled on & off during the following modes
// To enable a port to be toggled, place a 1 in the appropriate position
// Uncomment and update as needed
// Port 87654321
ReefAngel.FeedingModePorts = B00000011;
ReefAngel.WaterChangePorts = B00000011;
ReefAngel.OverheatShutoffPorts = B00001011;
//ReefAngel.LightsOnPorts = B00000110;
// ReefAngel.Relay.On(Port4); //Turn the Skimmer
ReefAngel.Relay.On(Port2);
// ReefAngel.Relay.On(Port1);
// Specific functions
ReefAngel.SingleATOHigh(Port6);
ReefAngel.StandardFan(Port1);
ReefAngel.StandardHeater(Port8);
ReefAngel.DelayedOn(Port4,10);
if (ReefAngel.Params.Temp1 > 290)
ReefAngel.PWM.SetActinic(PWMSlope(12,15,23,45,0,InternalMemory.LEDPWMActinic_read(),90,ReefAngel.PWM.GetActinicValue()));
ReefAngel.PWM.SetDaylight(PWMSlope(13,30,22,30,0,40,30,ReefAngel.PWM.GetDaylightValue()));
else if (ReefAngel.Params.Temp1 > 280)
ReefAngel.PWM.SetDaylight(PWMSlope(13,30,22,30,0,70,30,ReefAngel.PWM.GetDaylightValue()));
ReefAngel.PWM.SetDaylight(PWMSlope(13,30,22,30,0,InternalMemory.LEDPWMDaylight_read(),30,ReefAngel.PWM.GetDaylightValue()));
ReefAngel.DosingPump(Port3, 1, 05, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 1, 11, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 1, 17, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port5, 2, 23, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 05, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 11, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 17, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port7, 4, 23, 20, DP3_Timer); // Setup Dosing Pump 3 Oligo
