Actinic port not working
jjdezek
Post by jjdezek »
I got two wp40s and I noticed they weren't on so I started messing with them (unplugged and plugged back in) and managed to get one working but the other one wouldn't come on. When I switch them from the actinic ports the one port doesn't come on. Any ideas?
Re: Actinic port not working
What % do you see in the screen?
What code are you using?
Looking at your chart, there is something wrong that you are doing....
http://forum.reefangel.com/status/webch ... ilter=pwma
The PWM should not be over 100%
jjdezek
Post by jjdezek »
Not sure what changed, I reloaded my codes when I added the dosing pump Thursday. I will post my code later when I get home.
jjdezek
Post by jjdezek »
Got it figured out. Used an old code, must of had something different set up in it. Used most recent code and added dosing pump code and it's working now.
