Web Banners
Would you like to help?
Paulturner911
Re: Web Banners
Post by Paulturner911 »
Lets check. I have the following
http://forum.reefangel.com/status/banne ... 11&time=-5
Edit...Thas not right
Again
Re: Web Banners
Paulturner911
Re: Web Banners
I had time spelled out, I think it was on the first page to the thread.
Re: Web Banners
I fixed that post.
brettb
Re: Web Banners
Post by brettb »
What are the chances of having the water level displayed on the web banners? For those who have water level sensors.
Re: Web Banners
Yeah, I can work on that...
brettb
Re: Web Banners
Post by brettb »
Great stuff, Would be great to have. Water level is always a good indication of something gone wrong in a tank. My level expansion is on the way =)
Re: Web Banners
Done
brettb
Re: Web Banners
Post by brettb »
That is great! Thanks Roberto!
paulvisco
Re: Web Banners
Post by paulvisco »
Do you have a temlplate that one could work from (code) to generate a diffrent banner. i have a few ideas that i would like ot play with but...
having the backend code that generates the image is needed.. is it open or closed source..
Re: Web Banners
This should give you an idea.
I need to clean it up and optimize the SQL queries, but never had a chance...
paulvisco
Re: Web Banners
Post by paulvisco »
cool thank you..
monte455
Re: Web Banners
Post by monte455 »
Ok I tried to update my signature but it says I can't post links and to change or remove reef angel dot com, what gives?
Re: Web Banners
Think you need to have 5 posts...
Re: Web Banners
Spam couter-measure feature.
It won't let you post links until you reach a certain number of posts.
I removed the restriction on your profile and you should be able to post links now :)
monte455
Re: Web Banners
Post by monte455 »
Perfect much appreciated.
Sent from my SPH-L900 using Tapatalk
Xender
Re: Web Banners
Post by Xender »
Any ideas why my web banner doesn't update?
portal ans IOS App working good.
My web banner stay at 2012.
[img]http://forum.reefangel.com/status/banner_4.aspx?id=Xender&t=1[/img]
Fresh Water Aquarium 180*60*80
Salt Water Aquarium 60*60*60
Re: Web Banners
It was the last time your controller sent data to the server.
Maybe you enabled the portal key in the portal settings and never updated your code.
Try disabling the key.
Xender
Re: Web Banners
Post by Xender »
Nice it's was that !thanks!
