Hi,
Is it possible to have 3 pumps connected to a powerboard, that is plugged in to one power point on the RA, ie, controlling the power to 3 pumps with one powerpoint on the RA?
Power to pumps
wolffman64
- Sacohen
Re: Power to pumps
I'm not following you exactly, but I have 6 pumps plugged int a power strip and then that power strip is plugged into one relay on the Reef Angel. So they will all turn on and off at the same time and you are not using up valuable relays on the system.
Is that what you are trying to do?
wolffman64
Re: Power to pumps
Yup, that is exactly what I meant. Thanks for the answer to a slightly fuzzy question....
