raspberrypi expansion module
Re: raspberrypi expansion module
Ahhh. My PI has 2 ports, which I use for wifi and usb-ttl cable, but I'm pretty sure you can use a usb hub, can't you?
thoughtiknew
i can but it was just as easy to use my uart port infact i didnt even use a level shifter seams the ttl current is so small that it doesn't cause any problems now i am going to hook up the wifi expansion to another uart port and link the two that way the portal and internal webserver will work and then when i want to do an upload i can basically leaving the pi hooked up all the time
