Initially I used the Wifi Utility, and while it found my unit and gave me the IP address and port, it said "trying to find your router..." and never changed. Tried the wifi test code, nothing. I'm not sure why it couldn't find my router (Apple AirPort Express), but I mulled over the forums and kept seeing questions about old firmware. In Wifi Utility I clicked the button to update my firmware, and it jacked everything up... Tried to restore to factory setting, but no luck. It was only a few minutes ago that I discovered a few threads about how you should never click that firmware update button, because it'll screw the attachment up and you'll have to manually fix it with extra software.... Lovely.
So, my question is how do I do this? I tried following the link to download TeraTerm, but it takes me to the Microchip(dot)com homepage, and I haven't the slightest idea where to go from there. I would really, really love some (dumbed-down) instructions for how to get the software and fix my wifi unit. I'm leaving on vacation in less than a week and really wanted this new controller up and running
Thank you in advance!!
