Actinic channel not working
Recently I had a power outage and when the power was restored I found the actinic channel not working. The wavemaker connected to this channel does not spin. Also the wavemaker connected to the daylight channel just spins without any waveform. Luckily I had bought an extra relay box earlier. So I connected everything from the old relay box to the new one and the wavemakers are functioning as before. How do I rectify/ repair the actinic and daylight channels. Is it possible?
Dr Davaraj
Dr Davaraj
Re: Actinic channel not working
That looks like your chip may have gone bad.
If you open the relay box, you will see a LM341 chip. You must replace that one.
Thanks Roberto.rimai wrote:That looks like your chip may have gone bad.
Where do I locate the chip? Is it on the other side of the circuit board? How do I access the other side as there are no screws to take out.
- image.jpg (201.54 KiB) Viewed 9164 times
Roberto,rimai wrote:That looks like your chip may have gone bad.
The only chip that I can see is LM358P. Is that what I have to replace?
- image.jpg (225.08 KiB) Viewed 9154 times
Never mind. I managed to take the circuit board out from the main cover.davaraj wrote:Thanks Roberto.rimai wrote:That looks like your chip may have gone bad.
The jumpers are connected to analog. Can I change it to PWM to run the Jebao wavemakers?
- image.jpg (209.48 KiB) Viewed 9154 times
The Jabeo's can run as PWM or Analog. You can try changing to PWM to see if that functionality still works... not sure what the chip that Roberto is asking to replace does...
Yeah, that one. Sorry for the wrong chip. I was typing on the road
The markings are inverted. So, Analog is not really analog. It is in fact PWM.
Thanks Roberto,rimai wrote:Yeah, that one. Sorry for the wrong chip. I was typing on the road
I changed the chip for a new one and now both dimming channels are working as before.
