Moon rise/set implementation
Re: Moon rise/set implementation
Fantastic.. now both the slope and parabola functions will work am-pm or pm-am
thekameleon
Here is the code for the slope. its based off of Parabola
byte PWMSlopeOvernight(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
int start = NumMins(startHour, startMinute);
int end = NumMins(endHour, endMinute);
if (start > end) //Start is greater than End so its over midnight
//Example: 2300hrs to 0200hrs
if (hour() < endHour) start -= 1440; //past midnight
if (hour() >= startHour) end += 1440; //before midnight
int current = NumMins(hour(), minute());
int startD = start + Duration;
int stopD = end - Duration;
if ( current >= start && current <= startD )
return constrain(map(current, start, startD, startPWM, endPWM),startPWM, endPWM);
else if ( current >= stopD && current <= end )
byte v = constrain(map(current, stopD, end, startPWM, endPWM),startPWM, endPWM);
return endPWM - v + startPWM;
else if ( current > startD && current < stopD )
return endPWM;
// lastly return the existing value
return oldValue;
If the logic works then yeah. This matches the parabola logic and looks more like the original code than the original overnight that I started from...
The only con I see is the logic to add/subtract time only focuses on hours...if someone were to use it for a slope with less time or if someone wanted a slope/parabola from 11:55pm - 11:05pm...it might have an issue..maybe not... That would be the only point to check IMO.
I think actually it may be fine after reading it again...
Aemornion
Hello
I just signed up for this forum today to seek help with the moon.h library.
and as I am apparently too new to send a PM I shall post here. Hopefully this thread is not dead yet.
I am attempting to implement my own arduino tank controller, nothing fancy tank wise just my little 29 planted tank.
I started to learn the arduino in November for this purpose and have come a long way in the short about of time I have been chugging along and learning a lot in the process. =)
So I stumbled across this thread and the moon.h library, and real moon times is something i would really like to implement.
This might sound pathetic... but i am stuck on step 2
I have put
and the ide recognizes that as a valid library
no complaints their
But when I put
into the program, is complains
I have tried putting it elsewhere in the setup loop, outside theloop, different places within the loop. going as far as to delete everything else, except the necessary libraries wire.h, time.h, DS1307RTC.h.
Do you guys have any ideas as to why this would not be working? I am at a complete loss.
I am appreciative of any assistance offered.
-Jay
I have put
#included moon.hno complaints their
But when I put
moon_init(21,-73); into the program, is complains
moon_test.ino: In function 'void loop()':
moon_test:26: error: 'moon_init' was not declared in this scopeDo you guys have any ideas as to why this would not be working? I am at a complete loss.
-Jay
Welcome and good luck. Try this instead..Aemornion wrote:
I have putCode: Select all
#included moon.h
#include "moon.h"-
Aemornion
Thanks for the reply and assistance lnevo. =)
Alrght, so I made an error in my above statement, When i was
doing
I was actually doing
Which is what i do with all my other libraries standard with no issue.
Last night I did run through other iterations, such as using "" as you suggest which are outlined below.
Doing
yields an error of
(hence why i starting making <> standard a while ago)
and when i try
yields an error of
However the moon library is available under the arduino ide, being in the contributed section of the
sketch->importlibrary drop down menu, and when i select it to re import it, it tells me that their is already an moon library.
I should also note that these errors were acquired with the
code removed.
Here is my total code with all the fat trimmed off.
I left the RTC stuff in their because I am assuming that the moon.h library needs it at some point.
Thank you for any help,
=Jay
doing
#included moon.hCode: Select all
#included <moon.h>Last night I did run through other iterations, such as using "" as you suggest which are outlined below.
Doing
moon_test.ino:5:10: error: #include expects "FILENAME" or <FILENAME>and when i try
#include "moon.h"Code: Select all
moon_test.ino:5:18: error: moon.h: No such file or directorysketch->importlibrary drop down menu, and when i select it to re import it, it tells me that their is already an moon library.
moon_init(21,-73); code removed.
/////////moon.h test Program//////////
#include <moon.h>
//moon_init(21,-73);
setSyncProvider(RTC.get); // the function to get the time from the RTC
=Jay
The use of "" or <> depends on where you put the library.
I guess in your case the <> is appropriate.
Scope should not be a problem here if its included properly.
Can you try again now. #included was incorrect so maybe now that its #include?
Aemornion
Ah whoops, the "included" is an error on my part in the post, not in the actual program. It is most certainly include, not included in the ino
I noticed something else, I was using a lower case m rather than M in Moon.h
Now when i change it to a capital M
I get a slew of new errors about things inside the library
at least I know it is actually reading the library...i guess...
#include <Moon.h>at least I know it is actually reading the library...i guess...
In file included from moon_test.ino:5:
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:35: error: 'boolean' does not name a type
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:36: error: 'boolean' does not name a type
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:37: error: 'byte' does not name a type
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:38: error: 'byte' does not name a type
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:39: error: 'byte' does not name a type
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:40: error: 'byte' does not name a type
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:51: error: 'PI' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h: In function 'float lst(int, int, float)':
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:63: error: 'floor' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h: In function 'void moon(float)':
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:78: error: 'floor' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:85: error: 'PI' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:92: error: 'sin' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:106: error: 'cos' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:129: error: 'sqrt' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:130: error: 'atan' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h: In function 'float test_moon(int, float, int, float)':
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:165: error: 'PI' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:173: error: 'sin' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:174: error: 'cos' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:196: error: 'sqrt' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:203: error: 'floor' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:209: error: 'atan2' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:214: error: 'struct moon_t' has no member named 'riseH'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:215: error: 'struct moon_t' has no member named 'riseM'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:217: error: 'struct moon_t' has no member named 'isRise'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:222: error: 'struct moon_t' has no member named 'setH'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:223: error: 'struct moon_t' has no member named 'setM'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:225: error: 'struct moon_t' has no member named 'isSet'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h: At global scope:
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:231: error: 'boolean' has not been declared
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h: In function 'void riseset(int, int, int)':
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:235: error: 'struct moon_t' has no member named 'riseH'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:236: error: 'struct moon_t' has no member named 'riseM'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:237: error: 'struct moon_t' has no member named 'setH'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:238: error: 'struct moon_t' has no member named 'setM'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:271: error: 'PI' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:274: error: 'PI' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:279: error: 'struct moon_t' has no member named 'isRise'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:280: error: 'struct moon_t' has no member named 'isSet'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h: In function 'void moon_init(int, int)':
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:303: error: 'boolean' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:303: error: expected `;' before 'moonUp'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:309: error: 'struct moon_t' has no member named 'isRise'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:310: error: 'struct moon_t' has no member named 'riseH'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:310: error: 'struct moon_t' has no member named 'riseM'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:310: error: 'ScheduleTime' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:312: error: 'ScheduleTime' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:315: error: 'struct moon_t' has no member named 'isSet'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:316: error: 'struct moon_t' has no member named 'setH'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:316: error: 'struct moon_t' has no member named 'setM'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:316: error: 'ScheduleTime' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:318: error: 'ScheduleTime' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:321: error: 'moonUp' was not declared in this scope
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:331: error: 'struct moon_t' has no member named 'isSet'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:334: error: 'struct moon_t' has no member named 'setH'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:334: error: 'struct moon_t' has no member named 'setM'
C:\Users\Jay\Documents\Arduino\libraries\Moon/Moon.h:334: error: 'ScheduleTime' was not declared in this scope
Aemornion
Ok interesting,
I was able to knock out many errors by including
in my header, I have no idea why its just something random i found online to try.
anyway, now my errors read as follows. All are based around the 'ScheduleTime' function within the library.
Strange indeed.
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endifanyway, now my errors read as follows. All are based around the 'ScheduleTime' function within the library.
Strange indeed.
In file included from moon_test.ino:13:
ScheduleTime is a function in the Time library. Not sure if that's a standard arduino function or exclusive in the RA library. Anyway, you'll need that package. I did some conversion from the original package I found to make it work with RA.
You may also want to try the original as that may be more based on just Arduino standard libs...
http://code.google.com/p/stilo/
Aemornion
Hmmm, after much mullings
I removed
From the code. with the idea that from the looks of it that portion is not actually modifying the rise time and set time values, but rather sending those values elsewhere into your program.
and YAY it compiled!
Except the rise and set times are incorrect, so maybe that portion of code really does do something. sigh oh well ill figure it out eventually i suppose.
That you for all your help =)
-Jay
I removed
if (Moon.isRise) {
rise_time=ScheduleTime(Moon.riseH, Moon.riseM, 0);
} else {
rise_time=ScheduleTime(0, 0, 0);
if (Moon.isSet) {
set_time=ScheduleTime(Moon.setH, Moon.setM, 0);
} else {
set_time=ScheduleTime(23, 59, 59);
moonUp = 0;
if (rise_time < set_time) {
if ((tnow >=rise_time) && (tnow < set_time)) {
moonUp = 1;
} else if ((tnow >= rise_time) || (tnow < set_time)) {
moonUp = 1;
if (moonUp) {
if ( (!Moon.isSet) || ((rise_time > set_time)&&(tnow>=rise_time)) ) { //calculate for next day
riseset(latitude, longitude, 1);
set_time=ScheduleTime(Moon.setH, Moon.setM, 59)+SECS_PER_DAY;
}and YAY it compiled!
-Jay
Yeah those times are used during moon_init. Schedule time function returns number of minutes for that time...if you look at the original link it doesn't use that function so it may be in your library.
bencollinz
So, can you dumb this down for me, please? Am I putting values into somewhere or are they declared somewhere else? And I still need the moon.h file, etc?thekameleon wrote:Here is the code for the slope. its based off of Parabola
byte PWMSlopeOvernight(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue) { int start = NumMins(startHour, startMinute); int end = NumMins(endHour, endMinute); if (start > end) //Start is greater than End so its over midnight { //Example: 2300hrs to 0200hrs if (hour() < endHour) start -= 1440; //past midnight if (hour() >= startHour) end += 1440; //before midnight } int current = NumMins(hour(), minute()); int startD = start + Duration; int stopD = end - Duration; if ( current >= start && current <= startD ) return constrain(map(current, start, startD, startPWM, endPWM),startPWM, endPWM); else if ( current >= stopD && current <= end ) { byte v = constrain(map(current, stopD, end, startPWM, endPWM),startPWM, endPWM); return endPWM - v + startPWM; } else if ( current > startD && current < stopD ) return endPWM; // lastly return the existing value return oldValue; }
You don't need that function anymore. The regular PWMSlope function now works during any timeframe.
Latest version 1.1.0 compatible
Amos Poh
lnevo wrote:Hey guys,
So, I found this other aquarium controller code at http://code.google.com/p/stilo/ that had ported a javascript implementation of a Moonrise/set calculator into Arduino. I have adapted it to the RA libraries and it looks like it's working great.
Anyway if you want to have your moonlights follow an actual rise/set calculated based on GPS location, then here's what you have to do..
And then in your loop() function, add thisCode: Select all
#include Moon.h
You will then have access to the Moon struct which has the following definition:Code: Select all
moon_init(21,-73); // pass it lat / lon - it uses ints for the caclulation...
So you'll be able to do something like this:Code: Select all
struct moon_t { boolean isRise; boolean isSet; byte riseH; byte riseM; byte setH; byte setM; float riseAZ; float setAZ; }
or add this to your displayCode: Select all
if (Moon.isRise) { ReefAngel.PWM.SetDaylight(MoonPhase()); ReefAngel.PWM.SetActinic(MoonPhase()); } else { ReefAngel.PWM.SetDaylight(0); ReefAngel.PWM.SetActinic(0); }
sprintf(buf, "%02d:%02d", Moon.riseH, Moon.riseM); ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MR:"); x+=21; ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf); sprintf(buf, "%02d:%02d", Moon.setH, Moon.setM); x+=36; ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MS:"); x+=21; ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf); x+=36; if(Moon.isRise) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,"@"); else ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,"_");
Hi Lee thanks for sharing,
Just a few question hope you can assist me.
I am running 2 Rapid dimmable LED lightest, using analog dimming expansion.
the light set has 3 channels, 1 channel blue, 1 channel white and 1 channel UV red and green.
Currently iam running it to ramp up the different channels at different timing.
1)How can i use this code that you provided to fit into the different channel?
2)what should i do with the Moon.zip files?
Pardon my noob questions
The moon library only provides the times based on a gps coordinate.
First unzip the package into your libraries folder. The in your INO you need to put this in the top
#include <Moon.h>
You the have to initialize the library with your coordinates
moon_init(21,-73);
That will populate the Moon rise/set variables. Here's a sample to set the daylight channel based on the moon rise/set
ReefAngel.PWM.SetDaylight(PWMSlope(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM, 0,MoonPhase(),30,0));
It's not exact I think because of the lack of time zone support and that arduino thinks it's in GMT. I have not had time or care to get it to line up, but the key is that it creates a great lunar simulation with changing rise/set times.
Enjoy!
#include <Moon.h>
moon_init(21,-73);
Enjoy!
- Sacohen
Trying to understand how to set this up.
My Lunar Hub and lights should be arriving tomorrow.
I take the moon.h file and put it in my RA libraries folder.
Then add #include <Moon.h> to the top section of my code.
In the loop() function, add this
ReefAngel.PWM.SetChannel(5, PWMSlope(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM, 0,MoonPhase(),30,0));
I'm putting this on channel 5 of the dimming module.
According to a table I found online the Moonrise for tonight is 4:13 PM and the Moonset is 4:47 AM with the Meridian Passing time at 10:51 PM (is the the peak or azimuth).
Do I need to do anything with the numbers I made red aare those variables that can be adjusted?
Also if my Actinic lights come on at Noon and go off at 10pm will there be a period of time where no lights are on like 4:47am to 12pm, what will be happening there?
0 is the starting point for the slope. 30 is the slope duration. The last 0 os the default when the moon is not out.
As i said before i think timezone may skew when the ra calculates rise/set since ra does not use timezones.
Also you are comparing your rise/set but the gps coordinates i think were mine which is somewhere in the carribean...i guess close enough to you
If you want set Moon.riseH etc to a custom variable or display it on a custom screen to see what times are calculated...
- Sacohen
Yes you did mention the offset because of the time zones.
If I wanted to be more accurate with GPS coordinates I would put in moon_init(20,-80); // pass it lat / lon - it uses ints for the caclulation...
I got those from http://www.gps-coordinates.net/ for my address.
This works with Parabola too, correct?
Your just getting the rise and set time. You can use it for whatever function you want.
You could even add a check to see if moon is up and run your jaebos at a different mode or speed
moon_init just loads up the variables and then you can use them for whatever you want.
- Sacohen
I don't want to get too complicated right now.
I just want to set up a realistic Moon cycle.
I want to try to set this up on my own and not have to get others involved like I did on the de-nitrification system.
Do you want to just know what % of full moon today is or you need to know the time of moon rise/set??
I use just the % of the full moon and it works just fine
New moon, the tank is super dark and full moon the tank has a nice shine at night.
- Sacohen
I think what I want to do is use % of the moon, but set it to my on and off time.
For example my lights go out at 10pm so I would want the moon to be fully up by 10pm and then set at 12noon when my lights come back on.
My LED's are not set up yet so I'm just using my old Power PC's as an on/off.
When I get the LEDS running I will probably want to do a more realistic sunrise/sunset & moon rise/moon set.
So you just need the MoonPhase() function thats built into the libraries
- Sacohen
That will do % of the full moon?
