I have a Red Sea Max500 tank, with an additional Jebao WP-40 (will be 2 in the near future) and am waiting for my retrofit LED upgrade from Steve's LED (when I finally get them to answer my emails)
A short description of what I want to achieve:
To Measure:
- 2 x Temperature (in tank and in sump)
PH
Salinity
Water level in sump (high warning)
- Heater
Chiller
Chiller Pump
Jebao WP-40
3 circulation pumps (switch on and off as one total unit)
Return Pump
Skimmer
LED upgrade from Steve's LED with 3 "channels" (white, Royal Blue, and another type of blue I can't remember name of)
- RA+ controller
Salinity Expansion
Jebao Cable Harness
Wifi Attachment
additional Temperature probe
Socket adaptors (since I live in Australia)
- Is the equipment above correct for what I want to do?
Do I need the PH expansion module if I just want to measure it in one place, since the RA+ seems to come with a PH probe and port?
If I don't need the PH expansion module above, do I still need to get an expansion hub for now?
Do I need to get the Dimming expansion? It seems to me that the standard RA+ only can control 2 channels?
Is there a way for me to warn me about a low water level in my ATO, since the RSM500 has a completely "enclosed" ATO tank, and I will not be able to get a full float switch in the tank.
Do I still need to plug the power to the WP-40 into the power board, since I will control it through the cable harness?
How do I connect the control cable for the WP-40, is that Through the dimming ports? If so, I guess that will answer the question above about the Dimming expansion - I will definitely need it then.
