1. Where do you guys get these banners that have your parameters on them? Are they live?
2. I don't really plan on using the ATO floats more then warnings. I plan on having one float in the sump to act as a water level low alert. Can I use the second port to input a water sensor switch that will let me know if water is on the floor. These are the switches I already have.
Link was disabled by the request of the website owner. He did not want us to link to his website.If you wish to go to their page, you can copy and paste the link and change home-securitystore to homesecuritystore
They work with the breakout box on the aqua controller so I assume it is the same type of signal the float switches use. I don't want to burn up the controller. If I can use these can I run a few in parallel?
3. I have a few aqua controller expansion sockets that I have been using on my RK2 controller. Simply to remove the 1000w halide load off the relay box. Should I keep using these?
4. I might want to run an orp probe and an additional ph probe. Is there plans to add extra probe connections in the future?
5. I had asked in another thread if I could add a flow meter and you stated it would take something that outputs a pulse. What if I just want to determine if the pump is on. Could I use a pressure switch like this http://www.ebay.com/itm/Air-Activated-E ... 27c0c397a7
I would run an air tube up to the switch from one of the manifold outputs on my return. This would cause the air to pressurize and trigger the switch in the same manner the tunze and avast ATO operate.
6. I assume the only input for the RA are the float switch inputs. If I use one for a float switch and the other for some water switches in parallel I am out of inputs for a pressure switch to determine if the return is on. Could I make a little circuit that activates 1 input if its the float switch, the other input if its a water switch, and both if its the pressure switch? Is it possible to add a third channel with a simple circuit like this and have the RA assign these to alarms or actions? Is it possible to add even more channels by having the circuit pulse the inputs at different rates? Example would be a 4 channel break out box that outputs a pulse every .25s for ch 1, .50s for ch2, .75s for ch3, 1.0s for ch4, 1.25s for ch1 + ch2, ect ect...
I will probably come up with many more questions and will just add them to this thread instead of new ones
Thanks for your time,
Mark
edit: crap just realized I forgot to order the piezo buzzer...
