Wifi problem...Need help
Armetas
Post by Armetas »
Good day,
I bought ReefAngel controller with Wifi attachement, Relay, Orp extensions and extension hub. Trying to connect to my Wifi. Everything goes smoothly when accessing in own network, but connecting outside my network is a pain. Let's start from beginning.
My Internet setup:
Huawei B593 4G (192.168.1.1) -> Dlink DIR-615 (192.168.0.1) -> PC/Phone/Reef Angel
I managed to setup my Wifi to Dlink DIR-615 Router through Wifi_utility as 192.168.0.100
When connected to Wifi of Dlink DIR-615 router I can access 192.168.0.100:2000 page and everything is displayed.
In Dlink DIR-615 router I reserved DHCP address 192.168.0.100 for Reef Angel MAC and in port forwarding set 192.168.0.100 port to 2000.
In Huawei B593 4G (192.168.1.1) I added 2000 port for my Dlink router - 192.168.1.2
When trying to check port 2000 in yougetsignal(dot)com/tools/open-ports/ I'm getting that port is closed.
So I cannot access ReefAngel outside my network. Please help
Spent 2 days with this issue and now I'm dissapointed :(
Re: Wifi problem...Need help
The only thing I can think about is the wan IP of dlink.
Make sure it is 192.168.1.2
Armetas
Post by Armetas »
Huawei B593 recognizes Dlink by 192.168.1.2
What do you mean about WAN IP?
I think you need to connect to the ip address of the internet side of the huawei. That would be the ? You are missing. Also why most people use dynamic dns services.
Armetas
Post by Armetas »
lnevo wrote:I think you need to connect to the ip address of the internet side of the huawei. That would be the ? You are missing. Also why most people use dynamic dns services.
Maybe a little bit more info possible?
psirex
Post by psirex »
What is your public ip address?
GALAXY GOODNESS!
psirex
Post by psirex »
you can use sites like whatsmyip.com and it will tell you
GALAXY GOODNESS!
Armetas
Post by Armetas »
My ip is for example 188.69.213.189, but i don't know what should be in routers to make it work. Sorry my knowledge with routers is not so perfect...
Armetas
Post by Armetas »
Problem solved :) problem was that my IP was Dynamic, made static IP and everything goes smoothly :)
