The first is this slick little LED warning light system. I made this and connect it to a IO module. I was going to install it directly in the stand, but I thought this was easier and I can move it to another tank later. It was really easy to build, just a red, yellow and green LED with some resistors to keep the brightness down. It's handy that I can see it across the room and I get a little extra warning with the 'caution' yellow option. I have it signal temp pH, water level warnings. It is on yellow in these pics as it was topping off the water.
The second is the voice recognition module I started awhile ago. http://forum.reefangel.com/viewtopic.php?f=3&t=2521I squeezed it all into a project box and use a PIR to detect when someone is nearby and the module should be listening. The blue LED indicates it is listening. Here is what it looks like now. It can control the lights, powerheads, feeder, water change, as well as set back to auto.
Comments and suggestions alwyas welcome.
Jon
