Check out what came out of the oven today
It is a dual channel Jebao solar powered battery backup unit that will let you control two pumps with your Reef Angel controller and also keep your water moving when you lose power.
The battery is recharged using the power of the sun so you can rest assured that you will have a fully charged battery when needed.
The unit is engineered to sense power loss and switch to battery mode automatically, keeping your pumps running at lower speed until power is restored, at which point it will switch again automatically back to controller mode.
The unit is going to be sold at $125, which includes the solar powered charger, battery, the module and all the cables to connect them all together.
Be the first to order and you can get this prototype shown in the photos. Enclosure follows when they are available.
Click below to add to pre-order:
https://www.paypal.com/cgi-bin/webscr?c ... PRJZUNMGA2
