What I want to do is between the hours of 8 am and 9 pm be able to change my jebao from the portal and from 9 pm to 8 am only have it run what I have in the code, and not be able to switch it...and during that 8 am to 9 pm, have the "custom" switch from the portal run else mode...I keep getting an error about a brace being expected...
What am I doing wrong? am I missing a brace somewhere? Or what am I doing wrong...
ReefAngel.WaterChangePorts = Port5Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.CustomLabels[0]="Frag Pump";
ReefAngel.CustomLabels[1]="Actinics";
ReefAngel.CustomLabels[2]="Daylights";
ReefAngel.CustomLabels[3]="Frag LED";
ReefAngel.CustomLabels[4]="ATO Pump";
ReefAngel.CustomLabels[5]="Reactor";
ReefAngel.CustomLabels[6]="Heater";
ReefAngel.CustomLabels[7]="Fan";
ReefAngel.ActinicLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.ActinicLights( Port4 );
ReefAngel.SingleATOLow( Port5 );
ReefAngel.StandardFan( Port8 );
//ReefAngel.DCPump.UseMemory = false;
if (hour()>=8 && hour()<21)
if (ReefAngel.DCPump.Mode==Custom)
ReefAngel.PWM.SetActinic(ElseMode(60, 20, true));
} else{
ReefAngel.DCPump.UseMemory = true;}
ReefAngel.PWM.SetActinic(LongPulseMode(65,40, 60, true));
ReefAngel.Portal( "psyrob" );
if (WaveSync)
return NewSpeed;
return AntiSpeed;
else{
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Now this uploads, but I can't control it from the portal...
When I first upload it, the jebao sets to "0", it isn't running. Then I pick "custom" from the drop down menu in internal memory on the portal, and it runs in else mode, but then if I change to anything else (long pulse, lagoon, or whatever), nothing happens, it stays in else mode. It did switch to sine mode at the right time, though...
Any thoughts?
Rob
ReefAngel.PWM.SetActinic(SineMode(60,35, 20, true));
if (WaveSync)
return NewSpeed;
return AntiSpeed;
You mean when I switch modes on the portal? I think so...I tried reef rest, which I thought didn't use duration, I set speed at 65, I tried long pulse, set speed at 65, duration at 8...
