ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.ActinicLights( Port4 );
if (ReefAngel.DCPump.Mode==Custom) {
ReefAngel.PWM.SetActinic( ElseMode(ReefAngel.DCPump.Speed,ReefAngel.DCPump.Duration,true)); // ElseMode on sync mode, 35 +/- 5%
ReefAngel.Portal( "howaboutme" );
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
For the code below, I have assumed that in order to run a schedule, the pump code has to be hard coded. The code Lee (or you if you're reading
if (hour()>=22 && hour()<13)
ReefAngel.PWM.SetActinic( ConstantMode(30,true) ); // Constant at 30% on sync mode
else if (hour()>=13 && hour()<22)
ReefAngel.PWM.SetActinic( ElseMode(34,5,true)); // ElseMode on sync mode, 35 +/- 5%
if (WaveSync)
return NewSpeed;
return AntiSpeed;
