I see the values changing on the controller but the pumps isn't going what it shows.
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.Wavemaker1( Port5 );
ReefAngel.StandardATO( Box1_Port2 );
ReefAngel.CO2Control( Box1_Port3 );
ReefAngel.PHControl( Box1_Port4 );
ReefAngel.PWM.Channel0PWMSlope();
ReefAngel.PWM.Channel1PWMSlope();
ReefAngel.PWM.Channel2PWMSlope();
ReefAngel.PWM.Channel3PWMSlope();
if (hour()>=8 && hour()<11)
ReefAngel.PWM.SetDaylight( TidalSwellMode(40,true) ); // Tidal Swell at 40% on sync mode
else if (hour()>=11 && hour()<12)
ReefAngel.PWM.SetDaylight( ReefCrestMode(50,20,true) ); // ReefCrest at 50% + - 20 on sync mode
else if (hour()>=12 && hour()<13)
ReefAngel.PWM.SetDaylight( millis()%1000>800?80:0); // WaveMode on sync mode
else if (hour()>=13 && hour()<14)
ReefAngel.PWM.SetDaylight( ReefCrestMode(70,20,true) ); // ReefCrest at 70% + - 20 on sync mode
else if (hour()>=15 && hour()<18)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
else if (hour()>=21 && hour()<24)
ReefAngel.PWM.SetDaylight( millis()%1000>800?70:0); // Wave on sync mode
ReefAngel.PWM.SetDaylight( LongPulseMode(40,40,10,true) ); // Long pulse at 40% with 10s pulse on syncy mode
ReefAngel.PWM.SetDaylight(0);
ReefAngel.Portal( "ademster" );
