jaebo code not working,
PostPosted: Thu Apr 03, 2014 9:12 pm
Did you open the box to check?
PostPosted: Fri Apr 04, 2014 6:50 am
No, I just tested for voltage on the dimming port pins. with it commanding both actinic and daylight channel 100% no voltage..
Adam
58 Gal
PostPosted: Fri Apr 04, 2014 8:16 am
I meant open the box to see if you have old style box or not.
If it is one of the old style boxes, you will need a PWM booster add-on.
Check the revision of the board or take a photo.
PostPosted: Fri Apr 04, 2014 9:57 am
I'll open it up tonight
Adam
58 Gal
PostPosted: Fri Apr 04, 2014 7:06 pm
Revision 8.0 looks like the IC chip fried. burn marks all around the ic chip and also you can see it got hot around the legs.
Guess I have to order one and replace it
Adam
58 Gal
PostPosted: Fri Apr 04, 2014 7:17 pm
Adam
58 Gal
PostPosted: Fri Apr 04, 2014 8:02 pm
Looks like saltwater damage.
Previous
Return to My PDE/INO file
