Clueless Noob!!
Christo
Clueless Noob!!
Hi Guys!
I Just recieved my Reef Angel unit and Wifi Atachement! What do I have to do now?
Got no Idea!
Thanx
Got no Idea!
Thanx
Re: Clueless Noob!!
Download the user manual and the Reef Angel Installer on the website.
Install the installer and use the Reef Angel Wizard to customize your controller if needed.
Christo
Re: Clueless Noob!!
Okay everything is Done!
But like most I'm struggling with the wifi. After Using the wifi utility setup
on the last step it says "unable to setup port forwarding this has to be done manually"
How do we go about this?
Thanx
Thanx
Sebyte
Re: Clueless Noob!!
Port forwarding has to be setup in your router.
Check in your user manual for the router and also look at http://forum.reefangel.com/./viewtopic. ... forwarding
Christo
Re: Clueless Noob!!
Okay! Been strugling the whole day!! I logged into my router and it does not have a place where I can setup Port forwarding!!!
Any Help
Any Help
Re: Clueless Noob!!
Sometimes its listed under Applications & Gaming, what model router do you have?
Christo
Re: Clueless Noob!!
NETGEAR N300 Wireless ADSL2+ v2
Christo
Re: Clueless Noob!!
For some reason the v2 Is different then all the others!!
Christo
Re: Clueless Noob!!
Okay!! Done some more reading!! The router I have use Inbound and outbound rules!! Any Help welcome Please!!!!!!
Christo
Re: Clueless Noob!!
Now what do I do?
Christo
Re: Clueless Noob!!
Please Guys! Still need help Here? Everything is setup so far! The Wifi works thru my home network when I use my iPhone but cant access it thru the internet!'
Christo
Re: Clueless Noob!!
Any Takers on some Help?
- cosmith71
Re: Clueless Noob!!
What is your model number? Should be on a sticker somewhere on the router.
Re: Clueless Noob!!
You just need to create a rule to allow port 2000 to connect to the ip address of the reefangel. There should be a form to add a new rule. Post some screenshots if your that stuck.
Re: Clueless Noob!!
Also, try this:
www.simpleportforwarding.com
I think is some sort of key press generator that presses the right keys for you. I've heard from other users that it works.
