Eheim autofeeder
- Sacohen
Re: Eheim autofeeder
I removed the following and changed the trigger time to noon and it still did not come on.
Removed code
else {
if ( feeding > 0 ) {
feeding = 0;
Removed code
else {
feeding = 0;
You have two functions setting and the dcpump one maintains feeding=now() while in feeding mode. Change the eheimm to use a different variable name instead of feeding.
Thats why the code was there to reset feeding to 0...so will probably need to readd that with the new variable name.
- Sacohen
Ok. I'll give it a try
- Sacohen
Thank fixed it. Thank you for the help Lee.
I still don't really get coding. I thought since both the Auto Feeder routine and the DCpump feed routine both started with unsigned long feeding I could combine them into one section.
Its the behavior of how i used the feeding variable. In the dcpump version i keep updating it to now() while feeding mode is active.
The code would have triggered eventually (one minute after feeding mode finished).
The feeder one only changes feeding to now when you first enter feeding mode.
We can make them both work off the same variable, just need to change some timings. Once you get things where you want let me know when you update your thread and I'll take a look at how to do that.
- Sacohen
Ok. I haven't had luck soldering the relay to the feeder switch. Right now I have the feeder and RA in sync (well close) so when the feeder kicks in the RA thinks it triggered it and slows down the pumps. I just want to get something in place when I go on vacation in 2 weeks.
- Sacohen
The port is triggering as is should, but the RA is not going into Feed Mode like it does when I start fee mode thru the head unit or the App.
The pumps don't slow down, I don't see the 10 min countdown on the head unit and the system doesn't go into NTM after the 10 min feeding.
Is that because they need to be working off the same variable like you said above?
My current code with the exception of the Auto feed is in my sig.
Do you need the whole thing as is now?
Let me see what you have now. I think you may have renamed something wrong...
- Sacohen
Here is the code as it is now in the RA.
I renamed the function from feeding to autofeeding in the Auto feeder section
[/code][/code]
[code][code]#include <ReefAngel_Features.h>
// Define Relay Ports by Name
#define Actinic_Lights 1
#define Day_Lights 2
#define Unused 3
#define Pumps 4
#define Sump_Fan 5
#define DeNit_Doser 6
#define DeNit_Pump 7
#define Unused 8
#define ATO_Pump Box1_Port1
#define Moon_Lights Box1_Port2
#define Feeder Box1_Port3
#define Unused Box1_Port4
#define Unused Box1_Port5
#define Unused Box1_Port6
#define Unused Box1_Port7
#define Dummy Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
ReefAngel.WaterChangePortsE[0] = Port1Bit;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.DCPump.ActinicChannel=Sync; // Now you're pump will be affected by the portal settings.
ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
ReefAngel.WaterLevelATO(ATO_Pump,720,31,34);
ReefAngel.Relay.Set( Moon_Lights, !ReefAngel.Relay.Status( Actinic_Lights ) );
//AutoFeeder
static unsigned long autofeeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
ReefAngel.FeedingModeStart(); //START FEEDING MODE
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
ReefAngel.Relay.On(Feeder); //TURN FEEDER RELAY ON
ReefAngel.Relay.Off(Feeder); //TURN FEEDER RELAY OFF
} else {
if ( autofeeding > 0 ) {
autofeeding = 0;
// DeNitrate Routine
int DeNit_Offset=3600;
int DeNit_Repeat=21600;
int DeNit_Doser_Offset=1200;
int DeNit_Doser_Runtime=1200;
int DeNit_Pump_Runtime=1200;
int DeNit_ATO_Offtime=1500;
// Pump comes on first
ReefAngel.Relay.Set(DeNit_Pump,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
// Doser comes on second
ReefAngel.Relay.Set(DeNit_Doser,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
// Disable ATO
if ( (now()-3600)%21600<1500) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
// Delay WL ATO after water change and DeNit_Dosing
static time_t wcTimer=0;
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
// First 10 minutes after WC disable ATO
if (now()-wcTimer >= 0 && now()-wcTimer < 600)
// Track Salinity low duration
static unsigned long lastGoodSal;
static boolean lowSalFlag;
// Salinity is good, update counter
if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
// Counter hasn't been updating in 300 seconds..
if (now()-lastGoodSal>300) {
lowSalFlag=true; // Salinity is definitely below 33.5
} else {
lowSalFlag=false; // Salinity back to normal
// Disable ATO if lowSalFlag is true
if (lowSalFlag) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
// Disable ATO if ATO High IsActive()
// Add random mode if we set to Mode to Custom in portal
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3600) {
// Continue NTM for the 60 minutes
ReefAngel.DCPump.Mode=NutrientTransport;
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
// Night mode (go to 30%)
ReefAngel.DCPump.Mode=Constant;
ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==11) {
if (rmode==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true ); // ElseMode on sync mode, Portal Speed Setting +/- 20%
} else {
ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
} else {
ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Parameters
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
// Main Relay Box
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
// Date and Time
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
}- lnevo
The code looks fine. It should be triggering FeedingMode at 6pm...
Everything else is based on being in FeedingMode. The fact that the relay triggered which can only happen when in FeedingMode means that worked. So either something cancelled the mode, or the time for Feeding is somehow set low. Did you by chance update that during troubleshooting. Can you verify the value in memory for your feeing time?
- Sacohen
Not sure if you are following me when I say it triggered.
Port 3 on my Power Control Module is triggering the relay I have to trigger the feeder (not connected yet).
Nothing else is getting triggered.
I did not adjust the feeding time, because it works fine when hit feeding on the head unit or on in the app on my phone.
I just checked the Feeding Mode Timer value from the Android app and it is set to 900 second like it should be.
Yes I followed you...
The only way that the Port3 on the power control module can be turned on based on the code you showed is when the RA is in Feeding Mode.
The only way code that affects the start of FeedingMode is the check at 6pm. The rest of the code is independent and your RA should be in FeedingMode and the rest should trigger properly. Based on what your describing it sounds like your only in Feeding Mode enough to trigger the autofeeder.
Not sure what is going on... I'll try another look but it seems odd to me that it's not staying in Feeding Mode...
- Sacohen
I'll double check it tonight.
If I follow you, what you are saying is that it will not go into feeding mode if I manually trigger Port3 on the power control module thru the Portal of off of my phone it will only go into feeding mode if Port3 on the power control module is triggered by the code.
Is that correct, because my basis for saying that it wasn't working was I turned Port3 on the power control module on from my phone and didn't see anything else related to feeding mode happen.
Ok, yeah you have the method of how this works totally wrong
At 6pm, your controller goes into feeding mode nothing else happens.
60 seconds into feeding mode the autofeeder turns on. At 61 seconds the feeder turns off. This can be any time feeding mode is called.
It's all based on when your controller goes into feeding mode not when a port goes on/off.
- Sacohen
Ok. I though that triggering the relay was what put it in feeding mode, besides trigger the feeder.
I'll double check that it is working as it should (rather than ad I thought) when I get home.
Sorry for taking up your time on a misunderstanding.
- Sacohen
It works correctly. Thanks
RootsRockReefer
very cool idea with the eheim auto feeder. will have read up on this!
- Sacohen
It is a cool idea. I just suck at soldering and haven't been able to attache the relay yo the feed button properly yet.
I toasted one feeder already.
Gonna pick up a new one today and sync it to the RA so I at least have a feeder for while I'm on vacation next week.
- Sacohen
Is there a way to code it so that the Auto feed is disabled if I manually hit Feed Mode from the head unit, Andriod app or Portal?
I feed the tank with Reef Chili today and don't want to feed them again the flake food.
Plenty of ways...but you could just leave an override off on your feeder relay until you want it back on...
- Sacohen
So you're saying to do s manual override from the portal or app, and then take off the mask when I want it to run again?
It will still put the pumps in feed mode (0% in my case) and still put it in NTM after the supposed feed time, correct?
