Pump Schedule for WP-25
Re: Pump Schedule for WP-25
Yeah ReefCrest is pretty close. I'm not really sure the difference to tell the truth, but ElseMode is definitely more successful in the turbulence department :)
howaboutme
Post by howaboutme »
Well..speaking of reef crest mode. I set it w/ a avg speed of 36 and a duration of 6. Even w/ that, the portal (and reeftronics) is telling me that the pump is going (or has gone) over 50%....Something's not right there. My impression is that is should run in the range between 30 and 42%....back to constant mode to be safe... :?
Jack
Jack,
The Duration value is not used in ReefCrestMode. The +/- on ReefCrestMode is hard coded to 20% +/-
Lagoon Mode seems to be a bit gentler and will be the DCPump.Speed +/- 10% instead of the 20%.
Just so things make sense...
howaboutme
Oh! Didn't realize that. Thank you.
Jack
