Status App + ATO Timeout
peitro
Is it possible to reset the ATO Timeout Alarm using the ReefAngel Status App?
For some reason when my controller LCD goes into sleep mode, it does not wake up. All I get is a blank screen. The controller works fine, I just can't do anything that need me to look at the menu's (although pushing the button 3 times activates feeding mode, so the controller still works fine). If I reboot the controller, the LCD starts working again.
- Contact:
Re: Status App + ATO Timeout
Currently there is not a way to reset the ATO timeout alarm or Overheat timeout alarm via the wifi interface. It can only be done from the menu.
With that being said, I can add in this functionality and then incorporate it into the Status App (I'm working on an update for the Status App too). It may take me a couple weeks to get something working though given my work schedule and the Christmas Holiday coming up.
I use this trick:
I have ATO on my Expansion Box1 Relay8 and when I mask off that relay, it clears the ATO
The I just mask back to auto to resume normal ATO.
But it is very strange that LCD won't wake up.
Can you post your code?
if (ReefAngel.Relay.RelayMaskOffE[0]==127)
ReefAngel.ATOClear();
peitro
It is almost as if there is some kind of interference, when I try to wake up the screen it is either all white and blank or blank with flickering lines running across it.
// Autogenerated file by RAGen (v1.1.0.127), (10/22/2011 09:08)
// Modified to add moonlight control, light control, heater control
// RA_102311_BASELN.pde
// MEMORY LOCATIONS USED
// 103, 113 STRIP LIGHT ON/OFF HOUR
// 102, 112 MAIN LIGHT ON/OFF HOUR
// 121, 122 WAVE MAKER RANDOM LIMITS
// 11, 12, 13, 14, 15 PERCENTAGES FOR MOONLIGHTS
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#define SaveRelayState
#define WDT
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <avr/pgmspace.h>
// Labels for the web banner
prog_char id_label[] PROGMEM = "peitro";
prog_char probe1_label[] PROGMEM = "Sump";
prog_char probe2_label[] PROGMEM = "Refugium";
prog_char probe3_label[] PROGMEM = "Room";
prog_char relay1_label[] PROGMEM = "ATO";
prog_char relay2_label[] PROGMEM = "LED%20Main";
prog_char relay3_label[] PROGMEM = "LED%20Strip";
prog_char relay4_label[] PROGMEM = "Powerhead%202";
prog_char relay5_label[] PROGMEM = "Powerhead%201";
prog_char relay6_label[] PROGMEM = "Powerhead%203";
prog_char relay7_label[] PROGMEM = "Heater";
prog_char relay8_label[] PROGMEM = "Skimmer";
// variables for heater logic
int TFlag1 = 0;
int TFlag2 = 0;
int TFlag3 = 0;
// Initialize and start the web banner timer
ReefAngel.Timer[4].Start();
ReefAngel.FeedingModePorts = B01100101;
ReefAngel.WaterChangePorts = B01100000;
ReefAngel.OverheatShutoffPorts = B00100100;
// random timer for wavemaker
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(InternalMemory.read(121),InternalMemory.read(122))); //read times from internal memory
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port4);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port8);
// Specific functions
// turn on top off pump 4 times a day if float switch allows
if (hour() % 6 == 0){
ReefAngel.SingleATOHigh(Port1);
else{
ReefAngel.Relay.Off(Port1);
//turn on main light
//use memory 102 and 112
ReefAngel.StandardLights(2,InternalMemory.read(102),30,InternalMemory.read(112),30);
//turn on strip light
//use memory 103 and 113
ReefAngel.StandardLights(3,InternalMemory.read(103),00,InternalMemory.read(113),00);
// Turn off Port 7 when the temp of 2 of T1, T2, T3 gets above 82.0 degrees
// Turn back on when temp goes below 78
if ( ReefAngel.Params.Temp1 >= 820 ) {
TFlag1 = 1;
if ( ReefAngel.Params.Temp2 >= 820 ) {
TFlag2 = 1;
if ( ReefAngel.Params.Temp3 >= 820 ) {
TFlag3 = 1;
if ( ReefAngel.Params.Temp1 <= 780 ) {
TFlag1 = 0;
if ( ReefAngel.Params.Temp2 <= 780 ) {
TFlag2 = 0;
if ( ReefAngel.Params.Temp3 <= 780 ) {
TFlag3 = 0;
if ( (TFlag1 + TFlag2 + TFlag3) > 1 ) ReefAngel.Relay.Off(Port7);
else ReefAngel.Relay.On(Port7);
// Turn on moon lights based at different levels.
// use memory 11, 12, 13, 14 for levels
if (hour()>=19 || hour()<7)
if (hour()>=18 && hour()<21) {
ReefAngel.PWM.SetActinic(InternalMemory.read(11));
ReefAngel.PWM.SetDaylight(InternalMemory.read(11));
if (hour()>=21 && hour()<23) {
ReefAngel.PWM.SetActinic(InternalMemory.read(12));
ReefAngel.PWM.SetDaylight(InternalMemory.read(12));
if (hour()>=23 && hour()<1) {
ReefAngel.PWM.SetActinic(InternalMemory.read(13));
ReefAngel.PWM.SetDaylight(InternalMemory.read(13));
if (hour()>=1 && hour()<5) {
if (hour()>=5 && hour()<7) {
} else {
ReefAngel.PWM.SetActinic(InternalMemory.read(14));
ReefAngel.PWM.SetDaylight(InternalMemory.read(14));
// wavemaker code
ReefAngel.Relay.Toggle(Port4);
// Web Banner stuff
ReefAngel.WebBanner();
That interference is most likely caused by the inductance spike coming from your wavemaker pump.
Try placing the wavemakers on port 5 and 6, instead of 4 and 5.
Ports 5 and 6 have some special dampening components that minimize this effect.
In any case, to use the same trick I use to reset ATO through any app, place this in your code:
if (ReefAngel.Relay.RelayMaskOff==254)
peitro
Moving the wavemaker from port 4 to port 6 seems to have made a difference so far.
peitro
On the next version of the libraries, would it be possible to change the ATO function to allow a fraction of an hour for the ATO Timeout Interval? Or to choose minutes instead of hours?
Not a biggie since I can work around it by only activating the ATO on minutes % 15 == 0, but it would be nice to be able to just use the standard ATO function and change the value in memory.
hoyo
Hi,
I am using relay box port 1 to control my ATO, so which number can I use for this coding
thanks
JL
}JL
Should be the same.
When you mask the relay off, it should clear the ATO flag for you.
hoyo
Thanks Roberto,
I did try last night, I was using the iphone app, but it didn't work, should i place this code in the loop? what does the number 254 mean?
Yes, in the loop()
254 means you have only the port 1 masked off.
254 is the same as 11111110 in binary, where each bit represents on port.
